Page 43 of 59 FirstFirst ... 3339404142434445464753 ... LastLast
Results 841 to 860 of 1163
    #841
    Quote Originally Posted by joseph20 View Post
    How much po ba inaabot kay mang mario ng AC cleaning and freon charge?? like a sedan.
    Good question..Sayang din kc ung gas going to mang mario's shop, you also need to budget how much you'd bring with you, and not knowing if they can fix the problem would be a waste of both money and time..i know ganun tlaga, magastos tlga may oto..my point is..HINDI ba member mga mechanics ni mang mario dito sa tsikot..hehehe..astig sana..atleast straight from them, kahit estimate lang.
    #842
    bakit di mo na lang tawagan sa phone nila, hintayin natin yung mga may alam ng phone ni mang Mario, kasi ako tinawagan ko rin kasi tama ka para alam mo kung magkano ang dadalhin mong pera, kaya lang nawala na sa listahan ko ang number kaya di ko maibigay sa iyo.
    #843
    How long usually ang pagpapagawa ng aircon kay mang mario? ( gawa as in cleaning and takip mga butas ( kasi pumapasok ang usok, pag sa dagat naman amoy utot.)
    Oct 2009
    #844
    Quote Originally Posted by jojiesal View Post
    One side of the relay coil is connected in series with the thermostat, a/c switch, and fan motor speed control switch. The common terminal of the fan motor switch is grounded and there is a + 12v ignition switched connection going to the fan motor, the thermostat and the a/c switch which all seems fine. However, I traced the other side of the relay coil going to a small black box labeled WL81 located under the glove box compartment of my 2002 2.9L XL ranger. I don't know what exactly this box is for but it contains a small printed circuit board about the size of a cigarette pack. Is this an engine control unit and could this be the source of my problem. Could anyone tell me what this black box is?
    Is there a reputable auto a/c electrical shop that could readily analyze my problem and not do guesswork on my a/c problem.
    When it comes to electronics better keep the local shops aside and do it yourself. It is either you replace that unit (Anybody can do this) or have it repaired in some electronics shops. Most car shops have zero to no knowledge at all in electronics and is very disturbing watching them doing bypasses not to mention electrical tapes here and there.
    You are already correct with avoiding bypasses. This circuit board you are referring to is the same as in some cars, a module that triggers your A/C clutch. The moment you switch your aircon on it'll send signal by 12V or ground to trigger this circuit and from there it will trigger your A/C relay. Usually there is a protection diode that protects voltage spikes from the coil. This can be built-in inside your module or in the hood depending on make. This module is responsible in giving a delay prior to launch the A/C clutch to make the transition of the loads of A/C compressor load easier for the engine. This module also can be responsible to give signal to regulate your RPM higher to cope up with loads.
    In my honda civic for example. This goes together with the ECU. Other guys would just jump this bridge hence your engine will not like it and it is totally disturbing on the idle.
    If this unit is bad. It is possible that this unit can trigger aircon systems going on and off. Possible failures to this unit is a stupid mechanic hence destroying your electronics by periodically busting out your fuses by shortening things out or through flood/water/moisture.
    DIY is very simple and easy even for beginner when you have a helms manual with you. Wires are pretty much color coded and fail safe to install. Plug and play.
    Hope this helps.
    Oct 2009
    #845
    Quote Originally Posted by jerompot2002 View Post
    Hi po I'm new here at Tsikot....baka Kaya to ni Mang MARIO
    This problems happened to my Car all at the same time yesterday ....My car is Honda LXI 01
    Please Help po!!!
    1. Umaandar and blower ng aircon pero walang lamig (compressor di umaandar)
    2. Nawala ang power lock (central) pero ok ang power windows.
    3. Palagi naka ilaw handbrake indicator kahit na nakababa na.
    What do u think po ang problem?
    Napacheck ko na po sa dalawang good Auto Aircon Electrical shop (Rey's Auto Marikina at RAE Auto) di talaga ma solve ang problem. na try na din nila i recta umaandar naman lahat ng unit, walang problema sa compressor etc... sabi nila walang problema sa aircon unit
    They;ve check all fuse etc..... ok naman lahat kapag naka direct ay umaandar naman ang aircon. mukhang ang problem daw ay sa ECU or Computer box
    After almost 4 hours of analyzing walang nangyari....
    They referred me na to bring my Car to Honda Casa kasi nga daw mukhang computer box na ang problem..
    Help naman po baka may experience kayo na ganito ang problema na sabay sabay ang sira.....
    Thanks...
    I can guarantee you it is 95% the ECU. You don't need 4 hours to check this. Simply switch A/C on. If your RPM goes up like above 1k rpm and your compressor doesn't run it means your output signal of ECU is busted.
    Someone messed with your A/C and shortened the output to ground because this is usually protected with a diode and sometimes people just jumper this and voila instant burned ECU.
    If nothing happens it could be your ECU is not getting ground signal (for honda it's ground signal to trigger ECU to trigger the clutch). If this is the case the transistor needs also to be replaced.
    The ECU for honda i usually lower right side of the passengers side. Have your ECU repaired in Evangelista or so. They repair these units. I had this same problem and all it took was to replace the transistor IC responsible for the A/C inside the ECU. Purchasing a new one will cost you a fortune.
    Your CAR is running right? Meaning the ECU is not totally damaged. Why buy an entire ECU just because the A/C is broken. Get that transistor IC replaced or fixed. Some shops in evangelista repair those ECUs.
    Oct 2009
    #846
    Sa mga nag paayos kela mang mario. What equipments do they have? Do they have a leak tester? I think may leak ako somewhere in my system. My aircon ran for 4 years straight without cleaning or recharging.. Now I need to refill every 6 months or so. I'm looking for an A/C shop with leak detector. Kc sa mga tabi tabi they use soap. Don't think this'll work for very small leaks. I'm afraid that they might just charge me and do stuff on my car not to mention that no shop will put a 6month guarantee on their work.
    #847
    Quote Originally Posted by franzhelmer View Post
    I also have a similar problem but with a different twist. The coil side of my A/C compressor relay has a 12 v reading when I switched on the ignition without switching on the A/C switch and blower therefore my compressor is always "On" and doesn't cycle as it should . Two reputable shops failed to diagnose my A/C problem. I have a 2nd hand 2002 Ford ranger 2.9 XL. However when I brought it to Ford Commonwealth they said that my PCM(powertrain control module) is the culprit. I was shocked to know that my very old ranger's PCM will cost me P86,000.00. Looking for a second opinion I brought my unit to Rolly's Electrical at Don Antonio, QC and they told me that indeed it is the PCM. So Rolly said he could remedy the problem by installing an old school manual thermostat and bypassing the PCM. this only cost me P850 parts and labor. I agreed to bypass the PCM is so I could use my ride when it rains in the mean time that my PCM is still not repaired.
    My question now is will bypassing the PCM by my A/C affect my engine's performance and/or the A/C itself. My idling just went down a notch when my A/C is on however,I don't often use my ride so I really can't fully evaluate it at the moment.
    Last edited by jojiesal; November 19th, 2009 at 08:24 AM. Reason: added more information
    #848
    Do you know or could recommend some shops in evangelista that repair ECUs or PCMs
    Oct 2009
    #849
    Yes it is heavy on the engines side running the aircon on low RPM.
    #1 you get not so cool air as when having a good idle
    #2 it's very irritating to drive. your idle will drop when a/c kicks in during highway and traffic. you can get into accidents. Like kung d ka sanay na bigla mag up ung rpm pag nag cut off ung A/C then hit the car in front of you.
    #3 this is not the solution
    #4 will give you problems when converting back to orig.
    #5 No engine likes to idle at low rpms. It's stressfull for an engine. normal is 600 rpms~800 rpms for gas type.
    Solution is you get one at ebay. Note down the code model of your pcm.
    1L5A-BEC PCM module is for example 124.95$ . A good advise is shipping with DHL or Fedex around 40$~60$ (3~10 days). All you need is a credit card. I won't borrow mines sorry hehe. You need paypal or have a relative in the states.
    #6 it is harder to troubleshoot your A/C when something indeed goes wrong again. not to mention your original thermostat will be disabled.
    You don't want to mess with the Philippine customs because they are a pain in the TOOT specially in paranaque and might charge you unreasonably. Tell the aircon shop guys na ibalik yung dati or you'll regret that they might have messed up your original wirings and plugs. Happened to me already. Been there done that. They replaced everything with manual thermostats blahblah. The wiring was all left open with electrical tapes. I wanted to rewire everything back to orig but figured pinutol nila lahat ng plugs and wires. I had to rip off my entire wire harness just to trace which wire was which. Eventually I was cursing that A/C mechanic while I was converting it back to orig. I even had to buy the original plugs again from a surplus shop..
    I suggest you just get one from the states (2nd hand para no tax). Then plug it in. Then tapos na ung problema. Unless the technician messed your wirings na and doesn't know which is which and destroys your new PCM. 86,000 php is nonesense. If you need guiding assistance how to get your unit working you can PM me.
    Oct 2009
    #850
    If you have a 12V reading this means it's always grounded or shorted. Since your PCM output is PNP type. Meaning it gives ground to get the 12V and removes the ground by turning off. Yes try have it fixed at some ECU repair shop. It should cost you nothing to have it looked at. Could be transistor pack or diode is burned through. Diodes usually short themselves out very often. I had the opposite symptom before. It never turned on. But now it's fixed for 700php. Turns out some transistor were busted inside so I replaced em. Or check out "Speedlab" and ask them what they think.
    #851
    Thanks for the advice. The electrician cut only one wire, the one coming from the A/C compressor relay so i don't think I will have a hard time reverting back to the original A/C configuration. What also helped a lot is that I watched what they were doing very closely.
    #852
    Had my Galant repaired by Mr. Mario.
    Car Problems:
    1. Car not cooling when idle or slow pace running.
    2. Car intakes smokes from outside.
    What Mario found out after cleaning:
    1. Car not cooling because thermostat was pinned on the wrong place, making it switch mode. ( sinadya daw ng pinagawan ko dati.. pag balik kasi normal daw na malamig pero pag naipon na tubig, dun na babalik un sakit...)
    2. Duct was not fully closed, tinakpan ni Mr. Mario.
    What was done:
    1. Thermostat fixed.
    2. Freon re-charged.
    3. Cleaned Aircon.
    4. Closed ducts.
    Price: 700 only
    I felt very satisfied. Thanks for this great thread.. I spent 20k+ already on this aircon and still not fixed, lost hope and Mario to the rescue! :D
    Feb 2009
    #853
    Quote Originally Posted by kglzone View Post
    Car Problems:
    What was done:
    3. Cleaned Aircon.
    4. Closed ducts.
    Price: 700 only
    kgl, tanong lang regrding dun sa duct. San kaya banda yung duct na yun? Problem ko din kasi yang pumapasok sa loob yung usok sa labas kapag ON aircon ko. Kaya ba i-DIY? Though Toyota Corolla yung sakin, Gli bigbody. baka kasi same lang yung tinutukoy mong duct.
    Thanks
    #854
    pwede pa bang ayusin yang fresh air duct na yan, as palitan ang mga foam na nasira, para incase na gusto mong meron fresh air na papasok pwede pa rin.
    Aug 2008
    #855
    Quote Originally Posted by raine View Post
    Dapat talaga inaayos yang fresh air duct, hindi yung tinatakpan na lang.
    #856
    Well, i specifically requested it (duct) be totally shut off. (Rugby) :D
    Mario used a cigarette to test that no smoke enters after closing the duct. (Wise!!)
    Raine: Can't help you in identifying, I just asked the driver to take the car to the shop and talked with Mario on the phone.
    It took them the whole morning, 7:30 nandoon na nagaantay sa pila, mga 12 narin natapos. And it cost 700 only. That's why I feel compelled to make recommendations to this shop.
    So far, the air smells nice. Really comfortable during noontime and very very cold during evening.
    Mar 2004
    #857
    Guys, question lang...
    Bihasa din ba si Mang Mario sa pag gawa ng aircon ng mga latest model na sasakyan?
    Yung case ko kasi nabaha tapos yung aircon bumubuga ng hangin pero walang lamig. After cleaning and freon charging, wala pa rin! Sabi nung aircon tech, electrical daw ang problema.
    Kaya ba ni Mang Mario i-solve ang problema ko?
    Sep 2008
    #858
    mga sir,
    may nabili po akong l3 fb na 2nd hand dati may aircon kaya lang tinangal ng dating may-ari, balak ko sanang pa kabitan ng aircon kahit 2nd hand. any idea po ba magkanu aabutin, at saan pwdeng mag palagay, kalookan area po ako. maganda po sana kaya mang mario kaya lang marami po kasi akong ginagawa kulang po sa oras kung dadayo pa po ako.
    maraming maraming salamat po in advance.
    #859
    me landline po ba sila mang mario, pinagawa ko kai AC ko ast week sa banawe, sunog ako ng 10k. palit cooling coil, ayos ng leak, yun 2 duct kasi converted na to..
    so far ok naman lumamig, kaso yun buga ng hangin hindi nag improve, yun ang gusto ko maayos sana. hindi matino aircon ng mga converted from subic. ad y un amoy sa labas pumapasok pa din.
    sana maayos to nila mang mario, i know minor lang to sa kanila.
    ano kaya contact no. nila, very interesting ok sila gumawa base sa experiences ng mga nagpagawa
    Nov 2007
    #860
    bro...kung andyan pa yung gamit(mga dating ac system mga nd ka aabutin ng ganun.mga 15k...gusto u estimate natin?nd kita pababayarin pag nd ka satisfied.09282946925
Aircon Repair: Mario Reyes
