Originally Posted by
jick.cejoco
the fact that the subject vehicle is a 2006 chevrolet trailblazer, the refrigerant must be R134a and not R12; also, the fact that it is a chevrolet, it must be using an orifice tube; the fact that it is using an orifice tube, it must be using an accumulator/dryer and not a receiver/dryer- if there was a sight glass, the sight glass will always be cloudy since R134a appears cloudy and the sight glass (if equipped) is on the suction (low) side of the refrigeration circuit. the orifice tube may either be variable orifice tube valve (VOV) or a fixed orifice tube (FOV). the low side pressure varies between 27 psig to 35 psig. the outlet temperature is always advisable to be at 27 psig (32*F or 0*C). it should not freeze at this freezing pressure and temperature since warm cabin air and the cooling loads prevents this from happening and the pressure switch disengages the compressor clutch whenever the pressure goes down below 27 psig or the target temperature had been reached and cycles on and off. the discharge side varies with airflow across the condenser and the ambient temperature. the high side must be at least twice the static pressure of the refrigerant in the system at rest.
