Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Nov 2012
    Halo mga tsikoteers,tanung ko lang kung bibili ka 2nd hand na sasakyan paanu mo malalaman kung tinanggal ang thermostat na hindi mo babaklasin kung san siya nakakabit para makita.salamat kung my inputs kayo tungkol dito.
    Aug 2005
    Quote Originally Posted by fordman View Post
    Your warm up takes forever. That's because your coolant flow is continuous when it should be constricted during warm up.
    Essentially the thermostat shuts off coolant flow to regulate temperature.
    You will consume more fuel as your engine will burn richer.
    May 2004
    kapain mo yung 2 hose pag ka bagong start.. unang iinit yung isa...
    Sep 2005
    Matagal uminit ang makina. Mas obvious sya with short distance trip, di umaabot sa optimum temp ang temp gauge.
    Aug 2005
    TS what car are you working on?
    Open mo rad cap. Start the engine, if liquid in the radiator moves instantly, especially on a cold start then most probably wala na thermostat.
    Sent from my WT19i using Tapatalk 2
    Matagal bago tumaas ang temperature. Tapos ang temperature naman niya eh hindi stable. Pagka kasi may thermostat, maintain ang temperature ng sasakyan.
    Nov 2012
    Toyota liteace 2c-turbo sasakyan ko pala
    Nov 2012
    Ok salamat sir kaya ba pagnakapark na ako sabihin natin 4 oras ay pag inistart mo uli ay ang baba uli temperature gauge at tataas pag mga 2 to 3 minits idling?ang baba kasi idle ko at mausok pag cold start nanginginig p pero pag uminit makina at okay na ciya automatic tataas rpm nya.
    Aug 2005
    You're welcome, fordman.
    Sounds like your ride is in normal condition. Getting to operating temps within 2-3 minutes idling is normal. Cooling down within 4 hours should be fine too depending on ambient temperature and normal use.
ano ang senyales kung tinanggal ang thermostat
