Results 1 to 16 of 16
    medyo wla na lamig yung aircon ko, kaya pina check ko last saturday. sabi nung gumagawa eh kulang na sa freon. so, pinalinis ko na din saka pina kargahan ko ng freon. check na din kung may mga leak, wla naman nakita.
    nung matapos eh medyo ok naman lamig. pero nung bumabyahe na ako eh parang nde gnun kalakas ang lamig. nasa no.3 na eh nde pa din ako satisfied sa lamig, considering na umuulan pa nung saturday night.
    ano kaya problem? compressor na kaya? ano pa kaya dapat i pa check?
    btw, EE90 nga pala oto ko.
    Jul 2006
    baka meron kang baradong condenser
    Mar 2005
    Ipa-check mo kina Mang Mario (kung Metro Manila ka).
    Nov 2006
    Tha_Mann, bro if your in the south area, try the Ceejay aircon shop. Its near Perpetual Help hospital in Las Pinas if your towards Uniwide (alabang-zapote road) its towards the right side. Magaling sila at very professional and mabait yung owners.
    Quote Originally Posted by Tha_Mann View Post
    would you know kung ano compressor pressure mo? baka masyado na mataas which would mean barado yung components or tubing downstream. you can check previous threads regarding recommended high & low side pressure.
    Oct 2005
    Sir try nyo pa check iyung cooling coil nyo ang the expansion valve and drier baka barado and me butas sa coil.
    Kahapon galing ako sa CEEJAY's auto aircon shop sa may Las Pinas para pa check iyung van ko kasi hindi na rin ako satisfy sa lamig niya. Ang mga ginawa sa van ko ay:
    1. Pulldown both evaporator(dual) for general cleaning and leak test
    2. Welded one of my cooling coil due to pinhole(front)
    3. Pulldown compressor for leak test and replace bearing and oil
    5. Replace idler bearing
    6. Replace two pieces expansion valve
    7. Replace receiver drier
    8. Flushing of the two cooling coil pipes including the internal a/c piping system of the van using 141B chemicals. They done this to remove all the contaminants like dirt and oil that can cause clogged to my new expansion valves and driers. And me guarantee pa sa mga parts and ang the best ay pwede credit card pag short ka sa cash Ngayon ang lamig na sa loob ng van ko even a hot sunny day ;)
    Ang galing galing ng ginawa nila at talagang sistemado ang gawa pati ang staff nila ay very accomodating lalong lalo na iyung may ari na si mam cora and sir joel bow ako sa inyo Ngayon ok na siya even on a hot and sunny day even on traffic ok pa rin siya. Keep up the good work and bow talaga ako sa inyo
    tnx sa mga replies!
    makati area ako eh. hirap ksi sadyain si mang mario ksi saturday lng free day ko, baka madami nag papagawa on that day. baka ma try ko CEEJAY.
    too bad nde ko alam compressor pressure ko. ano ba normal na high & low-side?
    tnx again guys!
    Oct 2005
    tnx sa mga replies!
    tnx again guys!
    Sir tha_ mann ang ideal low pressure ng mga single a/c is 30-35 PSI ang low side. Try mo sa CEEJAY they are open ng 7am pa lang and Sat and Sun open din daw sila. The cleaning for a single a/c system is 1k lang plus parts kung me papalitan for 134a na yan sir. If you want to call them here is their number 8746003/8726856 look for mam cora and sabihin mo recommended ka ng tsikoteers na si fyke ang ride ay L300 baka mabigyan ka ng discount like she gave to me hehehehehehe.
    Aug 2005
    san kba nag papa service ng a/c mo sir?
    baka kulang parin ng freon yan ..
    or hindi balance ang pag ka lagay ng freon and oil .
    dapat sa marunong talaga..
    tnx fyke. mukhang malakas appeal mo kaya may discount ka hehe
    finchy, sa may pasay ako nag pa service nug a/c two weeks ago. binalik ko last saturday. nung tinignan eh yung fan ko eh mabilis mag auto off, cguro around 1 min lng eh nag off na kaagad kaya nde gnun kalamig ang binubuga. nung inayos eh gumanda ang lamig.
    pero kahapon eh galing kmi antipolo, pag punta namin robinsons east eh ok yung lamig nya kahit maanit ang panahon. pero pag uwi namin eh parang naging blower na lng, as in wla kahit konting lamig yung parang naubos yung freon. badtrip sobra init kahit gabi na. ano na naman kaya sira nun.
    nde ko nakita yung compressor pressure eh. yung ba yung may ikakabit sila na hose tapos yung parang may dalawa o tatlong gauge? ano ang hi & low side dun?
    tnx again peeps!
    Oct 2005
    tnx again peeps!
    Hehehehehehe hindi naman the_mann medyo naka chickahan ko lang si mam cora at medyo natuwa yata sa kadaldalan ko. Sir baka me leak iyung a/c line mo kaya naubos ang freon, check for a leak on your system. Ang low pressure side for a single a/c system is 30PSI lang ang high side di ko alam. You can see that duon sa pressure gauge na gamit nila na kinakabit sa compressor, if i'm not mistake color yellow, red and blue yata iyong mga kulay ng hoses na meron gauge sa itaas.
    blue hose for the low side, red hose for the high side and yellow hose for the vacumn and recharging inlet.
    fyke, magkano nagastos mo? Plan ko kasi ipaayos A/C ko tomorrow. Thanks.
    Quote Originally Posted by fyke View Post
    Oct 2005
    Quote Originally Posted by rolee007 View Post
    bro 7.8k lahat gastos ko kasi sa dami ng ginawa at pinalitan. Mukhang ngayon pa lang pinalitan lahat ng parts ng a/c ng van ko eh. Pero kung car lang ang ipagagawa mo at ipalilinis mo lang at walang papalitan na parts ay 1k lang singil ng CEEJAY sa Las pinas ito bro at kung van siya ay 2k naman. Just tell to miss cora na your from tsikoteer at referred by fyke na may L300 baka bigyan ka pa ng discount hehehehehehe.
    Salamat sa info fyke. Salamat lalo sa tip para maka-discount Napa-check ko na kasi A/C ng nissan b12 ko dito sa muntinlupa, sabi may leak ang coil. Repair at clean is 2.5k singil sakin (including parts daw). Dahil sa nabasa ko na mga good feedback sa ceejay, gusto ko ipacheck sa kanila at bka sakali ipagawa kng di lalagpas ng 1.5k ang gastos. sana mabasa 'to ni miss cora para may discount ako
    You can go for 40-45 psi for suction pressure for 134a freon charge at high ambient temp. For discharge nasa 200-250 psi.
Aircon problem
