Sir try nyo pa check iyung cooling coil nyo ang the expansion valve and drier baka barado and me butas sa coil.
Kahapon galing ako sa CEEJAY's auto aircon shop sa may Las Pinas para pa check iyung van ko kasi hindi na rin ako satisfy sa lamig niya. Ang mga ginawa sa van ko ay:
1. Pulldown both evaporator(dual) for general cleaning and leak test
2. Welded one of my cooling coil due to pinhole(front)
3. Pulldown compressor for leak test and replace bearing and oil
5. Replace idler bearing
6. Replace two pieces expansion valve
7. Replace receiver drier
8. Flushing of the two cooling coil pipes including the internal a/c piping system of the van using 141B chemicals. They done this to remove all the contaminants like dirt and oil that can cause clogged to my new expansion valves and driers. And me guarantee pa sa mga parts and ang the best ay pwede credit card pag short ka sa cash Ngayon ang lamig na sa loob ng van ko even a hot sunny day ;)
Ang galing galing ng ginawa nila at talagang sistemado ang gawa pati ang staff nila ay very accomodating lalong lalo na iyung may ari na si mam cora and sir joel bow ako sa inyo Ngayon ok na siya even on a hot and sunny day even on traffic ok pa rin siya. Keep up the good work and bow talaga ako sa inyo
