Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Jul 2006
    Bro, yung aircon ko may pumapasok na usok lalo na pag may merong smoke belcher na jeep or bus sa harap. ano kaya problem nun?
    Aug 2005
    what car? pa check mo yung vents na kumukuha ng air from the outside, baka sira na yung mga foam seals. you can have this permanently sealed kung di ka naman gumagamit ng fresh-air mode.
    Jul 2006
    *NazQ - my car is a Lancer gli 95'. thanks bro.
    Jun 2006
    Check mo yung lever(or button) ng Aircon, put it here:
    Aug 2005
    Its a worn-out foam vent dampers. Recommend to have it sealed permanently to prevent unwanted outside air odours and stick to interior air circulation instead.
    Feb 2006
    Quote Originally Posted by NazQ View Post
    +1 ako dito.
    if like mo pa ring gumamit ng air from outside, paayos mo lng yung foam seal.
    Aug 2005
    Quote Originally Posted by Steve1227 View Post
    oks yan, mitsu din yung sa akin. kakapagawa ko lang sabay na din cleaning. had it sealed since hindi naman ako gumagamit ng fresh air mode. kung sa las pinas area ka, try mo sa ceejays. HTH.
    Nazq: same problem sa akin, pwede ba nila i seal maski na hinde babaklasin yung evaporator? malamig pa kasi ang ac ko, pa service ko lang yung vents. magkano singil sa CJ's? thanks
    Aug 2005
    n5110> di ko sure sa Civic mo pero dun sa lancer kasi kailangan tangalin talaga dahil yung fan assembly nasa likod ng evaporator. andun kasi sa may fan assembly yung vent na tatakpan. nagpalinis lang ako ng evaporator pati karga ng r134a, kasama na daw yung seal sa service nila (1k). check mo na lang kung magkano kung yun lang..
    nazq> thanks pre, punta na lang ako dun pag nakaluwag ako. gaano katagal magpalinis ng system? thanks again
Aircon problem
