Results 1 to 4 of 4
    Dec 2008
    mga tsikoteer's i need your help...my 2000 honda civic aircon nag loloko na naman...pag ma init na yung engine ng car di na masyadong malamig ang buga ng hangin...nag pa cleaning na ako, tapos palit ng mga hose na may leak and pressure switch....pag naka stop yung car nag mo moist yung hose pero pag tumakbo na yung auto pag check ko yung hose di na sya malamig.... ano po kaya ang problema ng aircon ko?
    you need a manifold gauge set to see the cause of the problem, but you can do some preliminary checks like checking your cooling system. check mo yung space between radiator and condenser baka marumi na at nabablock and airflow. check mo din fans for proper operations.
    Dec 2008
    thank you sir!
    Jun 2004
    check if the fans are working, problem nung sakin dati isang fan lang gumagana kaya pag mainit nde malamig aircon
aircon not so cold when engine is hot...
