Results 1 to 9 of 9
- Oct 2008
- 469
August 11th, 2009 08:00 PM #1Help mga experts... My ride is: Sentra GA16DE EFI / MT
Problem: While tumatakbo auto ko, after 10 mins, bigla taas idling til 2000rpm. But pag nakahinto na, slowly going down naman Idle, pasumpong sumpong lang naman. Another problem po is pag naka ON AC, then pag andar, bumababa idle na parang ma deadeads na. What do I do is, OFF ko muna AC then ON after a minutes... Brandnew naman Evap. and Condenser ko, last freon charge ko is Dec 2008..
Servo problem na po ba or IACV clean lang?? thanks..
- Feb 2008
- 325
August 12th, 2009 04:30 AM #2kung malamig naman ang aircon mo, then wala sa aircon ang diperensya. i think na yung AAC valve mo ang may diperensya. might have to clean it or replace it.
Best to have it diagnosed using CONSULT para ma pinpoint ang exact fault. hth.
- Oct 2008
- 469
August 13th, 2009 04:54 AM #3kung malamig naman ang aircon mo, then wala sa aircon ang diperensya. i think na yung AAC valve mo ang may diperensya. might have to clean it or replace it.
- Feb 2008
- 325
August 13th, 2009 07:03 AM #4
- Oct 2008
- 469
August 14th, 2009 03:38 PM #5ask lang kita kung ok ba yung idling ng kotse mo pag patay yung aircon mo? saan naglalaro yung RPM needle mo?
- Mar 2004
- 652
August 17th, 2009 07:01 PM #6sir, ayun sa declaration mo, it seems na medyo nagluluko na ang idle-up valve mo. ang trabaho kasi nito is to increase the rpm of the engine pag umandar ang aircon kung ikaw ay naka idle. so, kung stuck yan, malamang pag off ng thermostat, hindi pa rin nag sasara ka-agad ang valve which tends to give you a high rpm.
- Oct 2008
- 469
August 17th, 2009 10:30 PM #7sir, ayun sa declaration mo, it seems na medyo nagluluko na ang idle-up valve mo. ang trabaho kasi nito is to increase the rpm of the engine pag umandar ang aircon kung ikaw ay naka idle. so, kung stuck yan, malamang pag off ng thermostat, hindi pa rin nag sasara ka-agad ang valve which tends to give you a high rpm.
August 17th, 2009 10:41 PM #8
Ipalinis mo iyong IACV idle air control valve, MAF hotwire sensor . Gaano na ba katagal nalinis iyon throttle body. Iyan kasi kadalasan cause ng erratic idling.
- Oct 2008
- 469
August 17th, 2009 11:13 PM #9Ipalinis mo iyong IACV idle air control valve, MAF hotwire sensor . Gaano na ba katagal nalinis iyon throttle body. Iyan kasi kadalasan cause ng erratic idling.
