Results 1 to 9 of 9
    Oct 2008
    Help mga experts... My ride is: Sentra GA16DE EFI / MT
    Problem: While tumatakbo auto ko, after 10 mins, bigla taas idling til 2000rpm. But pag nakahinto na, slowly going down naman Idle, pasumpong sumpong lang naman. Another problem po is pag naka ON AC, then pag andar, bumababa idle na parang ma deadeads na. What do I do is, OFF ko muna AC then ON after a minutes... Brandnew naman Evap. and Condenser ko, last freon charge ko is Dec 2008..
    Servo problem na po ba or IACV clean lang?? thanks..
    kung malamig naman ang aircon mo, then wala sa aircon ang diperensya. i think na yung AAC valve mo ang may diperensya. might have to clean it or replace it.
    Best to have it diagnosed using CONSULT para ma pinpoint ang exact fault. hth.
    Oct 2008
    Thanks sir for your reponse, gusto ko kasi my idea lang bago ko pumunta sa AC shop, the problem is pag nag automatic off yung thermostat, umaakyat idle ko til 1800rpm, steady siya for 1 min, and nawawala lamig, pag nag on na thermostat balik normal idle at lalamig na.
    Quote Originally Posted by joseph20 View Post
    ask lang kita kung ok ba yung idling ng kotse mo pag patay yung aircon mo? saan naglalaro yung RPM needle mo?
    Oct 2008
    pag nag OFF po ako ng AC, nasa 700 to 800 rpm. Medyo naglalaro din po Idle at hindi ganun ka stable. This last 2 weeks lang biglang nagkaganito auto ko. Pag naka On po AC ko, stable and RPM ko sa 900 rpm. Yung nga lang ang problem pag nag automatic off yung compressor, umaakyat sa 1800 rpm at naka blower nalang lamig ng AC ko. Any idea sir for the problem?? Thanks..
    Mar 2004
    sir, ayun sa declaration mo, it seems na medyo nagluluko na ang idle-up valve mo. ang trabaho kasi nito is to increase the rpm of the engine pag umandar ang aircon kung ikaw ay naka idle. so, kung stuck yan, malamang pag off ng thermostat, hindi pa rin nag sasara ka-agad ang valve which tends to give you a high rpm.
Aircon Malfunction. Is it Servo? or IACV?
