Results 11 to 16 of 16
September 5th, 2008 06:53 AM #11
baka kulang na freon mo.
its easy to say na thermostat nga agad ang problem, kasi ako nong yun ang sinisisi ko agad. matibay ang thermostat ng nissan..
anyways, pacheck mo baka kulang lang yan ng freon.. pag kulang yan, have them trace the system for leaks. kung walang leak, baka due to age lang kaya nabawas.
- Jan 2008
- 4,726
September 5th, 2008 09:09 PM #12*marv25, it will be better if you set the climate control temp to the MAX and adjust your temp by manual control (just be careful when the car is moving).... As i have said, HOT air is just mixed to the system and will just make your compressor WORK longer... When the system reached -5deg celsuis your A/C will automatically shut-off.. Try this at night especially when raining you will notice your A/C will shut-off but the cabin will be very very cold.. also check your AIR VENT Temp with a thermometer.. readings should be 9deg below (assuming your cooling system works fine)
my ride before can reach air vent temp as low as 0deg celsius during night with the thermostat at MAX setting..
what i have suggested is not hacking a "system" but rather improving what is already been there...Remember that car manufacturers usually DO NOT design their CARS based on Philippine Environment and some things are usually not applicable for us... It is better to know the system yourself and have possible options so that you can avoid A/C Techs giving you CRAP
all A/C units have "thermostats", they just differ in form and function... A/C units with climate control uses 2 common types of thermostat, 1: THERMISTOR or resistive type thermostat, LOW current control LOW VOLTAGE (just like what is installed to a Nissan Serena) when the system get cold (-5deg), the resistor will be in OPEN state and CLOSE when temp reaches 0deg and 2: FIXED Mechanical Thermostat, Low current control, (just like what is installed in Mitsubishi L300 Exceed Van) ... Other Cars without climate control uses Variable Mechanical or electronic Thermostat such as toyota vios, revo..
Thermostat even not in a Nissan vehicle usually lasts a very very loooong time... because they are in LOW Current application... usually when the system cooling efficiency drops, common causes are low charge, needs cleaning, leaks..
- Nov 2007
- 329
September 6th, 2008 09:31 PM #13I dont know if kulang nga sa freon... very malamig naman yung lumalabas na air...
Before we used to leave the temp at 18degC and just adjust the fan speed... but at one point we found that the fan speed will adjust itself if we adjust the thermostat to our desired setting so we leave it at about 27C and when it's hot, the fan will be at high, and when it's cold, it will adjust accordingly... but yun nga lang hindi talaga tumitigil-trabaho yung compressor...
Climate control is not meant for the philippines talaga... sometimes while driving and it gets cold, the intake vent will open nga by itself to "let in fresh air"... but hindi dito applicable eh... biglaan na lang iiba yung smell ng air...
- Nov 2007
- 329
September 6th, 2008 09:34 PM #14i dont understand lang why nissan designed the compressor to continue working even if its cold na... It would have been okay if the compressor would shut off when the desired temperature that is set sa thermostat is reached...
- Jul 2016
- 1
July 4th, 2016 07:31 AM #15Kapag converted na ba ang thermostat ng Tucson ang performance ba ng compressor hindi na cya nag shushutoff when turning off the ac switch in the thermostat? Fan is off but compressor is still continuously working.
Or is there problem with the newly installed compressor? Or wiring?
Help please. TIA
- 54,291
July 4th, 2016 08:23 AM #16
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
