Results 41 to 50 of 51
- May 2011
- 481
June 13th, 2017 04:41 PM #41Never base the state of charge on the appearance of the sight glass. This was a "good enough" ballpark indication of state of charge when cars still used dichlorodifluoromethane or R12 or freon but not for R134a or tetrafluoroethane. They can tell you of their wrong long experience all they can but you never use the sight glass for R134a
- Jun 2017
- 6
June 16th, 2017 06:22 PM #42Mga bossing pa-help naman po. Newbie here in tsikot. Yung 2009 hyundai tucson crdi ko nakita kong may bahid ng langis yung hose coming from compressor going sa bakal na connecting sa expansion valve. Sabi nila may leak pero malamig parin po ang buga ng A/C ko kahit 1 week ko nang nakita yung suspected leak. may slight hissing sound din sa loob pag nasa #2 or 3 sya. Ano kaya problem ng aircon ko. worried lang ako baka masira compressor ko Is this really a leak? Thanks Y'all!!!
BANNED BANNED BANNED
- Jun 2017
- 34
June 17th, 2017 12:16 AM #43the only way to know is to place a manifold gauge on the aircon system, evacuate the system, measure the recovered refrigerant and compared it with the specification, vacuum the system to test it for leaks... if no leaks, refill the refrigerant to specs...
aircon system has tolerances, it will still work within the specification it was designed with...
June 17th, 2017 02:59 PM #44
Here now in ceejay's and it looks like the evaporator coil is the problem. Kaching going on in my head ($$$$).
- Oct 2009
- 2,271
June 17th, 2017 04:04 PM #45nagpalinis ako last month lang napansin ko kasi ung filter dryer ko diba may salamin sa ibabawas un.pag naka on AC may circulation ng bubbles madami.at pag nag auto matic na siya.ung bubbles biglang nawawala at nakikita ko na bumababa ung freon ,after na mag on ulit siya lalabas ulit ung mga bulang paikot ikot..
ibig bang sabihin kulang ung freon na inilagay sa tsikot ko.134A ung naka indicate sa akin.kasi dati bago ko ipalinis hindi ganon ung nakikita ko sa filter dryer ko.halos walang bula talaga.meron man sobrang liit lang at hindi mo halos makita.
adventure 2008 nga pala tsikot ko..
- Jun 2005
- 3,774
June 17th, 2017 05:06 PM #46^ yung sight glass is only visual indication na puno or bawas.
Kung dati, after palinis, walang bula tapos ngayon meron na, there is a high chance na may leak.
Pacheck mo using gauge manifold para malaman gano ka kulang karga.
- Jun 2017
- 34
June 17th, 2017 05:36 PM #47
June 18th, 2017 06:49 AM #48
I was talking to the a/c tech at ceejays and he said the mazda's a/c systems are the hardest to clean. Aside daw from kelangan Baklas daw 2 pinto, pati dashboard daw tanggal. 3 days daw downtime nyan kaya mahal ang singil
Iyong ford fiesta at ecosport ganun halos din ata pero iyong focus madali daw
Ang mga mitsubishi easy daw except for the mirage. Kelangan daw Tanggal 1 pinto
Ang vios baklas dashboard. Dunno about the altis
Ang Mga honda ang fairly accessible to clean kaya usually cheaper ang singil nila. Di na kelangan magbaklas ng dashboard according to him
when you look into the abyss, the abyss looks into you
- 54,291
June 18th, 2017 07:30 AM #49
- Jun 2005
- 3,774
June 18th, 2017 10:25 AM #50
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
