Results 1 to 6 of 6
    Jul 2016
    Help naman po .. pag umaga kasi may nginig makina n parang palyado .
    pg mainit na makina ok na idle pero pg bukas ng aircon may nginig siya n parang nag dradrop rpm ko. Ano po ba issue pag ganun
    Jul 2016
    Quote Originally Posted by YooShh17 View Post
    Nissan xtrail 2003 matic po
    ano rpm pag nag engage ang ac compressor? nagtanggal ka ba ng battery recently? you need to adjust the idle air, unfortunately it can only be done by a capable scanner.
    Jul 2016
    Quote Originally Posted by t2erns View Post
    sir parang ganito issue ng saken eh
    pag bukas ko ng aircon parang my vibrate siya
    other things to check: vacuum leaks, pcv valve. but tthe way I see it you really need to relearn the idle air
    Jul 2016
    other things to check: Vacuum leaks, pcv valve. But tthe way i see it you really need to relearn the idle air
    problem solve na po sir sparkplug and coil lang.
    Other issue nanaman is mataas rpm nya pag off ac. Pg on normal. Ano po kaya posible issue
Nissan Xtrail aircon.
