Results 1 to 4 of 4
- Jul 2005
- 122
March 18th, 2008 01:17 PM #1greetings! patulong please sa aircon aux fan. minsan hindi umaandar pero pag ginalaw-galaw ko yung wires or the relay box(not sure kung yun ang tawag), umaandar na. I suspect that its just the connecting wires kasi malakas naman ang buga ng hangin.
I Observed that pag umaandar ang aircon aux fan, ok ang lamig. pag naramdaman kong hindi na malamig chine-check ko ang fan at ginagalaw ang wires para umandar at lalamig na ulit.
What should be done/checked? Thanks in advance.
- Jan 2008
- 4,726
March 18th, 2008 07:52 PM #2loose wiring yan.. possible young connection between main line to your fan... worst case eh loose wiring na yun sa main wire nung fan motor... you can buy a replacement aux fan or buy a surplus... i recommend buying a surplus japan compared to replacement.. mga 500 pesos lang naman yan..
aux fan is needed to dissipate the heat coming from the condenser... pag hindi na blow out yung heat coming from the condenser.. maapektuhan ang lamig ng aircon due to high pressure build up
March 18th, 2008 07:57 PM #3
sana loose wirings lang, but hinde naman mahal ang mga aux fans so, palitan na rin kung sira na, huwag na remedyo
March 19th, 2008 09:59 AM #4
could be the wiring, but it could be the aux fan motor na. just have it checked to determine what really is the cause of the problem.
for benchmarking lang... cost of the aux fan motor for my lancer 2000 model is 4,500.00 (brand new/replacement) and 6,500.00 (brand new/OEM).
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
