Originally Posted by oj88 That part of the centrifugal fan is sucking/pulling air. So if the filter has an airflow arrow, it should point towards the fan. yung pinakita ko pong bottom part yan po ba ang centrifugal fan? so kung nasa bottom part po iyan. the filter airflow arrow must point downwards?
Originally Posted by danegoesonline yung pinakita ko pong bottom part yan po ba ang centrifugal fan? so kung nasa bottom part po iyan. the filter airflow arrow must point downwards? The airflow arrow should point towards the fan. So if the fan is below the filter, then the arrow should point down. Better yet, watch this.
View Tag Cloud
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Sadly there are many cars now that don't have a spare, so it's either runflats or tire sealant.
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Yes, the Delica was not locally released. It shares the same engine, transmission and 4x4...
Found one on Marketplace : Log into Facebook
It was locally released as the "L300 Exceed", but no local 4x4 version. Same thing with the Space...
Enter your email address:
Delivered by FeedBurner
Liquid tire sealant
