unable to decipher vehicle make or country of origin. but, the most common magnetic clutch coils have about 1 ohm of resistance. hence, current=voltage divided by resistance (12 volts divided by 1 ohm gives you 12 amps, higher than 10 amps fuse you had. the fuse could be protecting the airconditioning amplifier. the condenser blower uses 15 amps fuse, the evaporator blower uses 15 amps
