Results 1 to 15 of 15
    hello mga sirs. kailangan ko po ng tulong.
    Nagbabawas po ng tubig sa radiator, and nagooverflow ng tubig sa water reservoir. Tumataas yung temp ko ng 3/4. I hope hindi naman siguro ito Head gasket issue as we just used the car last weekend going to baguio and wala naman problems pag uphill and high RPMs. sa traffic lang talaga tumataas yung temp hangang 3/4. I recently replaced all the hoses, radiator flushed, and new radiator cap (0.9). My car is civic LXI 97
    What could be the problem?
    Thanks Tsikoteers!
    Dec 2009
    Quote Originally Posted by albert1911 View Post
    Thanks Tsikoteers!
    Humina na yung Aux Fan. Have that checked
    Quote Originally Posted by andywesteast View Post
    Agree. This is the most common culprit.
    Thanks for the quick feedback mga sirs. will definitely check the Aux fan this weekend. But I am also thinking of upgrading my rad cap to 1.1 to sustain the pressure inside the radiator. I just thought that baka kaya nagooverflow yung tubig sa reserve dahil hindi kaya ng rad cap (0.9) yung pressure? or maybe its a busted thermostat? Anyway, I will try to replace my aux fan this weekend. I'll keep you guys updated. Thanks!
    Sep 2010
    sige bro,share mo kung ano talaga problema,nangyari na din kasi sa delica ko dati,pag akyat ko ng baguio..
    I say stay stock. If your system was designed for .9 then use the .9. Have the aux fan checked nga. One sign of weak aux fan is increase in temp during traffic
    Quote Originally Posted by edtf View Post
    Thanks for the feedback sir. But one thing I thought of is, baka kaya lumalabas yung tubig sa radiator at pumupunta sa reservoir dahil hindi nya kaya yung pressure? That is why I thought of having my rad cap upgraded to 1.1 sir. but you're right, kaya siguro nagbuibuild ng pressure sa loob dahil sobrang weak na yung fan and di na nya napapalamig yung water sa radiator.
    pls update us kung ok na yung car mo after replacing/repairing the fan....
    Sep 2010
    bro,ang aux fan ba,iba sa engine fan?engine fan located between the radiator and the engine?if I am right,normal ba na ang karamihan sa diesel engine,walang aux fan?tulad ng delica at crosswind ko?
    Oct 2009
    Quote Originally Posted by acergy09 View Post
    opo magkaiba po aux fan sa engine fan,, mostly po aux fan pag gasoline engine yung naka kabit mismo sa radiator, pag diesel po karaniwan may engine fan yung between engine and radiator.
    kung medyo tumataas temp nyo during trafic pwede po nyo lagyan ng aux fan sa kabila ng radiator, pero make sure po na pabuga or papunta engine yung flow ng hangin, kasi yung nakakabit sa engine pahigop naman papunta rin engine.
    Oct 2009
    Thanks Tsikoteers!
    malamang po mahina na nga fan kung during traffic lang nangyayari.. check nyo po baka kailangan nang palitan or check nyo rin po grounding nyo baka mahina na ground kaya di na makaikot ng maayos ang fan.
    wag po nyo palitan ng cap, kasi baka sa iba naman pumunta yung over na pressure ng radiator nyo,
    nangyari po sa akin yung cap ko di ko pinalitan ng cap pero dinoble ko yung goma, ayun resulta di nga tumapon sa reservior tubig,\pumutok naman yung hose ko..
    Quote Originally Posted by shedell View Post
    nangyari po sa akin yung cap ko di ko pinalitan ng cap pero dinoble ko yung goma, ayun resulta di nga tumapon sa reservior tubig,pumutok naman yung hose ko..
    Thanks sa advice sir.
    Just an update, I already replaced my radiator fan last weekend. Pero parang ganun pa rin, napupunta pa rin sa reservoir yung tubig from the radiator. This time, Im thinking the thermostat might be the culprit. Maybe the thermostat is not opening when it reaches the desired temperature to operate. kaya pag nag high pressure, bumabalik yung tubig sa reservoir.
    anymore inputs mga sirs?
    May 2009
    a thermostat that fails to open will overheat the engine. a thermostat that stays open all the time will overcool the engine. an engine without thermostat will overheat on traffic and overcool on highway runs....
    is the cooling system bled thouroughly? after topping up coolant, start engine and let it idle up to operating temp then race engine several times until it bloats at the rad neck.....
    to check head gasket sealing, with the engine cold remove rad cap and crank engine over...if the radiator filler neck vomits coolant, it's a head-block sealing problem. if it doesn't vomit, with the engine cold start engine with the rad cap on. just after a few seconds remove the rad cap and see if pressure have built up. one more thing is the presence of bubbles......that's the DIY method...specialized shops have complex devices for checking these. sorry got no info with regards to these shops with these equipment.
    Feb 2005
    Dalawa lang ang problema niyan, kailangan overhaul yong rad kasi baka may mga barado ng tubo at nag ooverflow sa top cover dumideretso sa expansion tank (reservior) at palitan yong rad cap baka mahina na.
    Quote Originally Posted by miked View Post
    yung sakin naman sir, pag naka idle, umaapaw yung tubig sa filler neck ng radiator. then pag rinev ko, hindi bumubulwak yung tubig. instead, pumapasok sa loob ng radiator yung tubig. but what makes me think that it is a head gasket problem is that there are bubbles during idle. and kumukulo yung tubig sa radiator. Though I haven't tried cranking the engine in cold start while the rad cap is off. will try that later.
    Quote Originally Posted by dest View Post
    Thanks sa input sir. pero almost new pa po yung radiator ko eh. given it's still new, I already had it lavramon'ed para sure. but the problem still exist. and for the rad cap, bumili na rin ako ng bago. I am now using 1.1 but ganun pa rin, napupuno pa rin yung reservoir ko ng tubig. almost napalitan na lahat, hoses, fan, rad cap. two nalang ang hindi, the THERMOSTAT and the HEADGASKET.. pero kung headgasket nga, any shops na magaling magpalit ng headgasket? and any idea how much magagastos ko for the labor and parts? Thanks mga sirs
Radiator Water Reservior Overflow
