Originally Posted by
autofrost
Guday tsikoteer, the main cause of the damage to your compressor obviously was the busted radiator fan and condenser fan, it causes your aircon system to go on high pressure, thus damaging your compressor. If you notice prior to your car aircon cleaning, on idle speed, cooling was not sufficient enough, because cold air passing your condenser was not enough to lower the pressure on your condenser. Condenser fan is triggered once you turn on your a/c system, radiator fan is triggered by temp sensor switch on your engine. SOP on my shop, once you replace a busted compressor, you also need to replace the condenser to protect the new compressor against clogged system, you did not buy a separate filter drier because brand new condenser comes loaded with filter cartridge, expansion valve replacement is not a must to be replaced, you can just flushed it with nitogen. But its your option to replaced it or not. Here in my shop, my cost for a brand new keihin compressor, condenser, labor, refrigerant flushing, etc, will cost you around 26t, it comes with a 1 year warranty.
