View Poll Results: Replacement parts options
- Voters
- 167. You may not vote on this poll
OEM - CASA priced, normally 10% discount
69 41.32% -
Quality branded parts - same as OEM but not high priced as opposed
123 73.65% -
China/Taiwan made parts - quality issues, but lesser than branded
8 4.79% -
Locally made - less quality than China/Taiwan best bargain
6 3.59% -
Pre-used parts - life span cut by 50%
4 2.40% -
Stolen parts - no warranties, use at our own risk
1 0.60%
July 18th, 2005 07:42 PM #11
i go for OEMs for critical parts like compressors, radiator fans, alternators and as such. pero i go for replacements dun sa mga non-criticals or semi-criticals such as oil filters, shock absorbers, etc.
July 19th, 2005 02:19 PM #13
ang mga replacement parts na nasa car ko ngayon ay KYB shocks, GMB water pump, 555 brake pads at NGK wheel bearings.
July 19th, 2005 04:21 PM #14
Originally Posted by chris_d
July 20th, 2005 02:43 AM #15
I think you should consider changing a worn out part after you get into an accident because of the worn out part. Or was that you should do it before? ;)
I'd go with OEM or better.
SiRaNeko
- Jan 2003
- 973
July 20th, 2005 06:05 AM #16price wise
sa konting diprensiya, sa oem na. especially kung critical part like t belt etc. den pag oem usually sa casa para sigurado and pwede credit card. =)
pero kung me oem outside of casa na reliable naman ang seller, don na ko bili.
other than that , replacement will do pero dapat high quality din. wag naman yung sobra mura. siguro yung mga 1st-2nd class replacement ok pa.
July 21st, 2005 12:54 AM #17
i usually go with OEM parts, may bad experience na rin kasi kami sa mga cheap parts hehe
pero sa tulong ng tsikot, i now know which quality replacement parts to buy na hehe
July 22nd, 2005 08:41 AM #18
OEM but not from the casa. Pre-used (hehe second hand) kung kilala ko yun previous owner so I'll know how long he/she has used it.
July 27th, 2005 09:30 AM #19
pag engine parts, i go for oem not from casa. pag suspensions 555 brand will do and i buy sa mismong suppliers sa manila, kahit mga oil seals and bearings I personally buy them para orig na and cheaper pa. Nakabisado ko na nga maynila kakaikot para sa mga parts na ito. Yung surplus parts naman usually na bibilhin mo ay mga door mouldings, rear view mirrors or any accessory na hindi maapektuhan ang performance ng car mo, interior baga?. Pero sometimes kung dun lang fit and budget, mas ok kumuha nun kesa replacement na tsina.If you're going to buy replacement parts tanung mo yung "mas japan" at sigurado may ilalabas pa syang iba. pag japan lang, yun ang japeyks!
July 29th, 2005 09:46 AM #20
for our ford lynx, we went to this repair shop in pasay (jojie's) and had the auxiliary motor and fan blade replaced with a surplus one from a toyota. exacto and size and they just refitted the original lynx frame. total cost: PHP1,200 lang
so far, its been 2 months and wala namang problema. na solve tuloy ang overheating sa lynx and erratic rpm during idling
now, the car runs smoothly
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
