Results 11 to 20 of 98
October 14th, 2007 03:39 PM #11
Chuaed, car wax works that way. It beads water so it will easily flow off.
The windshield repellant is only different in that it is clear. You can wax your windshield if you want, just make sure you completely buff it off after letting it dry. It has the same effect. Buff with a clean towel para walang streaks. Make sure you also look through the glass from inside the cabin so you can see kung may streaks or not. This is the best way to avoid streaks when you least need them like when driving towards the sun/west.
October 14th, 2007 03:49 PM #12
yes, did it before. dami beses na ko nag-apply ng rain-x sa body ng car. works better than auto glaze since the water does not stick to the car body. but now there is already rain-x wax. made by the same company that makes rain-x windshield rain repellant. works as a wax and water repellant at the same time. so yun na gamit ko sa car body since isang application na lang (where-as before had to apply wax, then rain-x or auro glaze so doble hirap).
December 7th, 2007 10:12 AM #13
Question, full tint yung tsikot ko sa loob and labas, will rain-x work on this?
December 7th, 2007 11:05 AM #14
i'd recommend rain clear. its like a wax for the windsheild. the glass is smoother and glossier after. plus it doesn't contain alcohol unlike rain x. alcohol+rubber= bad combination.
December 7th, 2007 11:31 AM #15
Any feedbacks sa Elevo Brand i saw at Concorde? its a winshield cleaner and also rainmark/watermarks remover?
Last edited by carlos; December 7th, 2007 at 11:34 AM. Reason: product description
Tsikot Member Rank 4
- Oct 2004
- 2,315
May 27th, 2008 03:20 PM #17
- Jun 2006
- 12
May 28th, 2008 05:52 PM #18
- Mar 2009
- 72
April 24th, 2009 07:37 AM #19Saan po available ang turtle wax rain repellant at Rain X. Hindi kasi ako maka hanap nito sa shops na napuntahan ko. Salamat
April 24th, 2009 08:37 AM #20
Tried RainX once a few years ago. I wasn't really impressed with it....
(Mabuti pa iyong yosi na dinurog at ibinudbod mo sa windshield...... :hysterical:
7909:taunt:
Maintaining proper tire pressure is crucial for safety and performance on the road. Ensure your...
Tyre pressure
