Results 1 to 8 of 8
- Jun 2008
- 3
March 21st, 2009 02:52 PM #1mga bossing, question lang po, ano po ba ang easiest way to remove the old tint sa windshield sa likod. thanks. xenxa a po nahihirapan na ko sa blade eh.
March 21st, 2009 03:01 PM #2
leave it to the expert, pag hinde ka marunong baka masira yun defoggers mo
- Jun 2008
- 3
March 23rd, 2009 03:08 AM #5
There is an existing threads about film removal here. You should brows it. Anyway, have to repeat again on how to remove a tint film.
Follow this procedure.
1. Cut the garbage bag in roughly the shape of the window, spray soapy water on the outside, cover it with the black trash bag and smooth the plastic flat.
Most window tint is constructed of multiple layers of film. When left under the hot sun, the garbage bag will absorb heat, helping the film peel off in one piece.
2. Protect all inside surfaces near the rear window with a tarp: speakers, rear light, and upholstered surfaces kung hindi mababasa ang mga yan, then spray the entire window film with undiluted ammonia.
Undiluted ammonia has a strong smell. It is recommended that you hold your breath or wear a face mask.
3. While the ammonia is still wet, trap the ammonia against the window film with another trash bag or plastic wrap. Park the car with the rear window facing the sun for an hour to soften the tint's adhesive.
4. Now we can start peeling the window film. Use your fingernail or razor blade lift the window film in a corner of the window, and try to peel the film off in one entire piece. Keep the tint moist with ammonia as you strip.
Use a razor blade to scrape off any tint that did not peel. Be careful not to cut the defroster lines.
5. Remove the any residual adhesive with ammonia and Super-Fine steel wool, wiping with paper towel before it dries. Remove the exterior trash bag, and clean window thoroughly with glass cleaner.
[SIZE=4]Good luck at kaya mo yan.[/SIZE]
- Jun 2008
- 3
March 23rd, 2009 09:11 AM #6mga bossing thanks sa mga reply, hehe! nakalahati ko na sa mano-manong blade lang. hahaha!!! pero gagawin ko yung post mo para hindi ako masyadong mahirapan sa bandang ilalim. thanks po ulit. Godbless
October 2nd, 2012 03:50 PM #8
actually, kahit hindi na ammonia solution.. basta spray mo lang ng water with shampoo yung rear glass mo then lagyan mo ng plastic then pabayaan mo lang kahit 1 hr then scrape it off gently then pinanglilinis lang is blade para sa mga adhesive na dumikit sa glass para malinis before lagyan ng tint ng bagong tint..
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
