mga sir, anu ba tawag jan? hindi naman siya scratch mark, i think sa windshield wipers galing. pano ba tanggalin ito?
hindi siya palalim sir, parang naka umbok nga siya eh, hindi ko makuha sa madiin na punas ng microfiber..
Kung sa windshield wipers galing,
Baka dagta ng puno na natulo sa wind shield and nahagod lang ng wipers, then natuyo.
Or kanin na napahid sa windshield, then natuyo.
Try mo sir wet rag with soap, kung hindi scratch and hindi mighy bond na napahid at natuyo, madali lang matanggal yan.
windshield detailing mo na lang Sir, average cost nun asa 300Php.
Per buy ka na muna ng pamalit sa wiper mo, advisable kasi na after mag windshiled detail ung luma mong wiper palitan mo agad.
Just to aguila glass have the windshield replaced 4k plus lang bnew pa. Installed na yun
Before getting your glass replaced try cleaning first with a solution of 50% strength solution of isopropyl alcohol. Soak the area with the solution using a spray bottle, let it sit for a minute to give the solvent time to work, then try wiping off. If that doesn't work, you can move to a dedicated chemical glass cleaner - I've used Mothers California Gold Water Spot Remover to great effect, removing two-year old waterspots from my hand-me-down company leased car. There are also acid-based cleaners such as Elevo which will be a bit stronger, though you need to exercise more care in using these (gloves, at minimum, better with eye and breathing protection).
ganyan din yung mark sa toyota ko hindi kaya ng elevo. naiinis na nga ako.
