Results 1 to 17 of 17
    May 2007
    im not sure kung dito ko dapat ipost to.. anyway tinry ko gumamit ng paleta (yung ginagamit sa pag masilya) pero mejo nagagasgas yung salamin so tinigil ko.. me masusuggest ba kayo na tamang paggawa nito? TIA
    Aug 2005
    a simple cutter lang po sir pwede na. ganun lang po ginamit ko pang tanggal ng conduction sticker, di naman po gagasgas yun sa windshield basta "patagilid" lang po ang stroke ng cutter.
    Jun 2007
    try using a blade or a cutter. ingat lang baka masugatan ka. i've tried it na eh mas madali siya compared sa kamay or sa iba pang methods. cutter: just parang i pahiga mo siya then gently peel the sticker then kapag may lumabas na part ng sticker hatakin mo na lang with your hands. hope this helps.
    May 2007
    salamat.. try ko cutter bukas hehe mejo madilim na e baka masugat ako..
    salamat ulit
    Aug 2006
    Try mo hot water,,, then saka mo tuklapin
    Jun 2007
    hot water o kaya acetone.. bawat tuklap mo ng sticker pahidan mo ng acetone tapos tuklap ulit..
    Feb 2006
    cutter lang yan, yung malaki ah para madali talaga tanggalin, remove the blade from the casing syempre o pwede din kasi mabili yung cutter blade replacement sa mga hardware for 10php. i used pliers to hold the blade para may pwersa ako since madikit talaga yung conduction sticker
    Quote Originally Posted by lnce420 View Post
    ..also don't forget to wear safety goggles (if you have or borrow one) yung clear or maybe a simple pair of shades. This way you have a some protection just in case the blade snaps and might chip off some debris into your eyes.
    It can happen so better safe than sorry.
    With all due respect sa mga nag recommend ng cutter....using a cutter is the riskiest way to do it.
    Hot water on a towel. Tapal mo for awhile. You may even pour some on the sticker. Then peel with your fingers.
    Aug 2004
    tamang tama ang thread na to. i'm planning to remove din kasi ng conduction sticker namin. i'll try yung mga suggestions nyo, bro tomorrow. thanks.
    May 2007
    salamat sa mga nagreply.. natanggal ko na yung sticker before reading na puwede yung hot water/acetone method.. anyway scalpel ginamit ko and its relatively easy, di nascratch yung salamin pero chagaan it took me arnd 10-15mins to remove the whole thing
    Aug 2005
    I always use the ice method + tweezers sa sticker removal.
    tried it on the following:
    - conduction sticker (mga 5 years old)
    - yearly registration
    - yearly village stickers
    procedure:
    - ice the sticker for several minutes. i use a cloth/face towel to do this para di masyado makalat at madali hawakan yun yelo.
    - use the tweezers to get a hold of one of the corners (for square/rectangle stickers), pag circle just try to get a hold any part.
    - pull the sticker slowly (use diagonal angles in pulling..)
    BTW, sa glass lang po ito.. i never had to remove any sticky residue.
    Ingat lang sa cutter muntik ng matamaan mata ko.
    lagyan mo ng WD40 para mas madaling tanggalin.
    Driver ko ginamit nya blade. Tapos ung mga tira tira, nilagyan ng gas. Daput lagay muna sa pamunas para di tumulo and ingat na ingat dapat. Tapos pa-carwash para ung mga boy na ung maglinis and matanggal ung baho.
    Sep 2006
    did you use force in it? dba khit minimal lang tagal na :peace: peace
    Quote Originally Posted by bankai View Post
    Hindi naman masyado lagi ko kasing ginagamit cutter na yun.
    Jun 2007
    +1 ako sa cutter method
    pero ingat baka ang balat mo ang matanggal
pano magtanggal ng conduction sticker without scratching the glass
