Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Nov 2012
    Any suggestion sir para makagawa ako ng hole enough for me to see my side mirrors. Ang dilim kasi ng tint nahihirapan ako lalo na pag gabi. Thanks.
    Jan 2011
    Change tint to light
    Palitan mo na lang ang tint ng 1-2 shades lighter yung driver and passenger side windows. Pangit sir. I did that with one of my rides nagsisi lang ako. Ended up doing what i should have done in the first place, which was to replace the tint.
    Pero if you insist, plastic plate at box cutter lang katapat nyan. Tape the plate to the window in 4 or more places, cut around in between the tape, then put tape where you have already cut (to prevent the plate from moving when you remove the first tapes), then remove the first tapes and cut where they were. Remove plate and peel off the tint. Remember to apply very light pressure when using the box cutter. Madali lang magasgas ang automotive glass.
    Then pag tapos na iiyak ka, kasi pangit hehehe!
    +1. It's fugly
    another option is; keep your dark tint intact, just have a neat vertical cut then peel off up front where-in you can see your side mirrors good enough then have it tinted with 1 shade lighter.
    gaps wouldn't be obvious from the outside just like how they do it with the windshield. hence super dark/black next to a medium dark tint shouldn't be that much obvious from the outside either.
    Retro look...
    Quote Originally Posted by gadtechs View Post
    it's easy.
    use a blade that's easily available at bookstores.
    use a round item like a platito, if you want round hole.
    use a ruler if you want straight edge hole.
    but i agree with cat. it's ugly.
    but it's cheap.
    Davai!
    Mar 2013
    Panget niyan windows down na lang [emoji1]
    Nahihirapan ka ba habang nagddrive? Ako naman nahihirapan pag nagpapark patalikod tapos madilim. Binababa ko na lang bintana.
    Nov 2012
    Hirap po kc mag change lane pag gabi. If mahina or walang ilaw yung nasa likuran ko e hindi ko makikita. At sa pag park din po kelangan ko pa i windows down (manual windows pa naman haha). I picture out at pag isipan ko muna since mukhang panget nga kalalabasan nito. Try ko yung suggestion ni sir benchman. Thanks mga bossing sa feedback.
    actually, the solution is obvious, only we refuse to do it.
    the price of vanity..
    Aug 2012
    just change all your front glasses to light or medium tint. ganyan naman standard abroad eh. dito lang sa Pinas mahilig sa manyak tints. safety first.
    Jun 2005
    nakakaduling ang dark tint tapos biglang may butas na walang tint.
    patint ka na lang ng lighter shade
    Jun 2012
    Dark tints tapos di naman makita. Talaga naman o
    Palit tint nalang kesa gagawa pa ng butas. Ang pangit pangit tignan ng butas ang bintana para lang makita ang side mirror.
    Tint na may butas for windows, mas jologs pa tingnan for me kaysa visor tint lang sa windshield.
    Di ko gets sa mga tao bakit kumukuha ng super dark tint tapos di naman pala kayang magdrive ng ganun kadilim.
    di naman dahil pasaway yung may super dark tints. reason po dyan e kasi daytime naman pag choose at install ng tint e di naman obvious pag daytime na sobrang dilim pala pag gabi. kaya pag dating pa lang sa gabi saka pa lang nakikita na nagkamali pala. ang problema pa lalo since mahal magpa-tint e wala naman na budget para magpapalit ng tint agad. ako nga inabot ng 1 year bago nagkabudget ulit kaya 1 year din ako nagtiis na nago-open ng windows kapag uma-atras pag gabi.
    Similar thing happened to me. I was surprised at how dark my tint was. Buti na lang medium lang yung front and back pero yung side hirap din ako magpark pag madilim yung parking. Binababa ko na lang windows ko.
    Hulaan ko sunod na tanong: Ano kaya mas maliwanag na ilaw?
    I usually advise my nieces to have full dark tints (tolerable shade) just to protect themselves. Yung low life's kasi, pinipiling pag tripan babae kesa lalaki. Kung tinted salamin all around, di na pagkaka interesan.
    Feb 2009
    Dumbf$cks wear a blindfold and ask for more light
Tint hole for side mirror
