Results 1 to 10 of 10
- Sep 2009
- 35
October 17th, 2009 11:58 PM #1Pag nag drive ako at malakas ang ulan parating nag moisture ng windshield ko kaya panay punas ko ng windshield kapag nag drive ako. Ano ba best way or product na gamitin para hindi gaano mag moisture ang windshield kapag umuulan. Kahit A/C on or off. Hasle kasi kapag mahaba ang byahe at lalo na night driving.
October 18th, 2009 12:44 AM #2
tantsahin nyo nalang po yung temperature sa labas at sa loob ng oto nyo..minsan po kailangan talagang lamigan ang aircon para di mag moist yung salamin..or keep the windows slightly open
- Sep 2009
- 35
October 18th, 2009 09:54 PM #3ganun ba? thanks ha..sorry ngaun lang ako nagkakotse kahit 2nd hand kaya wala pa ako gano alam.. thanks again.
October 18th, 2009 11:01 PM #4
There are products that you can spread on the windshield to minimize the fogging effect.
The other way is to use the aircon system to blow air across the windshield. Just adjust the vent blower selector and switch the A/C air type to use air from the outside.
The main reason why the windshield is fogging up is that air inside the car is getting heavy with warm water vapor from our breath. The cold windshield glass makes the water vapor condense, creating the fog. Venting the cabin air with air from the outside will help minimize this. You can do this by simply opening the windows or using the fresh air vent control on your A/C.
October 18th, 2009 11:07 PM #5
- Sep 2009
- 35
October 21st, 2009 08:39 PM #8
Wala bang malalagay na moisture absorber? Kasi sakin mapa-araw at ulan na naka park merong moisture sa loob. Walang tao to ha. Baka kasi basa pa ng kaunti ang upuan nung nilagay ko kaya in heat nag eevaporate. pero in rain? kakaiba.
October 22nd, 2009 09:04 PM #9
possible din po na sa morning sobrang init at naipon yung init sa loob, then biglang ulan habang mainit pa yung loob kaya nagkaroon na ng fog sa loob..
October 22nd, 2009 09:11 PM #10
Bro nabaha pala yung auto ko. Additional factor din yun, baka kasi basa pa yung nilinis kong upuan o yung carpet ko sa baba pero ilang linggo na yun. Balak ko maglagay ng silica gel eh, kaya nga lang baka dry air na ang mahinga ko pag nilagay ko sa loob ng kotse.
