Nagpalit po ako Unipoint Soft Wipers/Banana Type. Pati likod sinabay ko na.
*480each yung harap 20"
*380 likod 15" (soft din)
Hirap maghanap. Nalibot ko na banawe isang shop lang meron kaso yung ordinary di soft/banana.
Mag bosch aero soft banana type sana ko kaso 1.5k pair pa lang.
Googled kung san ang dealers, sa masangkay cor recto daw meron.
Dito ko nakakuha.
Rotary name ng store, Dealer talaga sila Unipoint.
1133 G Masangkay St. Sta Cruz
251-7787, 251-1063
0917-8900900, 0922-8999866 www.rotaryauto.com.ph
Eto po description from a seller sa sulit kaso wala sya ready stocks by order pa daw kay dumerecho na ko sa dealer.
Unipoint wiper blades (Aeroblades) are flawlessly quiet because its rubber is graphite coated. Graphite coated meaning, it does not produce a squeaking sound when wiping the windshield and kung papansinin niyo pag hinawakan niyo yun blade madumi siya yun ang Graphite Coated Rubber yun ibang brand wala niyan Secondly, the rubber doesn't go brittle when subjected to heat and the cold temperature (rain temperature). Thirdly, Unipoint is the manufacturer (maker) of Bosch wiper blades (aeroblades). Which means, Bosch and Unipoint blades are the same and performs exactly the same except of course for the packaging and the price.
