Results 1 to 8 of 8
    Jun 2008
    mga bossing, question lang po, ano po ba ang easiest way to remove the old tint sa windshield sa likod. thanks. xenxa a po nahihirapan na ko sa blade eh.
    leave it to the expert, pag hinde ka marunong baka masira yun defoggers mo
    Jun 2008
    wala naman po ako defoggers
    patira mo na lang din yan bro, mura lang labor nyan...
    May 2007
    There is an existing threads about film removal here. You should brows it. Anyway, have to repeat again on how to remove a tint film.
    Follow this procedure.
    1. Cut the garbage bag in roughly the shape of the window, spray soapy water on the outside, cover it with the black trash bag and smooth the plastic flat.
    Most window tint is constructed of multiple layers of film. When left under the hot sun, the garbage bag will absorb heat, helping the film peel off in one piece.
    2. Protect all inside surfaces near the rear window with a tarp: speakers, rear light, and upholstered surfaces kung hindi mababasa ang mga yan, then spray the entire window film with undiluted ammonia.
    Undiluted ammonia has a strong smell. It is recommended that you hold your breath or wear a face mask.
    3. While the ammonia is still wet, trap the ammonia against the window film with another trash bag or plastic wrap. Park the car with the rear window facing the sun for an hour to soften the tint's adhesive.
    4. Now we can start peeling the window film. Use your fingernail or razor blade lift the window film in a corner of the window, and try to peel the film off in one entire piece. Keep the tint moist with ammonia as you strip.
    Use a razor blade to scrape off any tint that did not peel. Be careful not to cut the defroster lines.
    5. Remove the any residual adhesive with ammonia and Super-Fine steel wool, wiping with paper towel before it dries. Remove the exterior trash bag, and clean window thoroughly with glass cleaner.
    [SIZE=4]Good luck at kaya mo yan.[/SIZE]
    Jun 2008
    mga bossing thanks sa mga reply, hehe! nakalahati ko na sa mano-manong blade lang. hahaha!!! pero gagawin ko yung post mo para hindi ako masyadong mahirapan sa bandang ilalim. thanks po ulit. Godbless
    buhayin ko lang thread na'to. where can i buy an ammonia solution.
    Jul 2004
    Quote Originally Posted by Ginnova View Post
    actually, kahit hindi na ammonia solution.. basta spray mo lang ng water with shampoo yung rear glass mo then lagyan mo ng plastic then pabayaan mo lang kahit 1 hr then scrape it off gently then pinanglilinis lang is blade para sa mga adhesive na dumikit sa glass para malinis before lagyan ng tint ng bagong tint..
tint removal (rear)
