Quote Originally Posted by jujjay View Post
hi all! so my new windshield tint got damaged when i pulled the suction cup of my dashcam. the size is that of a 10 peso coin. it is behind the rear view mirror so nobody can see it, except when you are outside. my tint is the lightest 3M.
question is, is there any diy process i can do to fix this? if not, should i leave it be or will it get bigger overtime? replacing the tint is my last option. Thank you!
new tints, meaning you just had it installed?
if so, may tendency talaga na sumama sa suction cup yan,
hayaan mo muna dapat matuyo ng husto yung tints.
i also have 3m tints, 4 years already, may dashcam din ako,
and also before, phone mounts. ilang beses ko na nilipat lipat sa windshield,
ok pa naman.
unless pag nagtatanggal ka ng suction, inuunlock mo nga yung locking mechanism,
then todo sa paghila ng suction, may suction padin kasi yun kahit naka disengage na.
thus, sasama.
what i do is, unlock the suction mechanism, then pry mo sa isang side nung cup
hanggang magkahangin na yung ilalim, then kusa na syang bibitaw.
regarding sa problem mo na ngayon, try mo flatten ulit yung film with a card,
carefully, baka magkafold naman yung film pag binasta basta hagod lang.
