Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    May 2016
    hi all! so my new windshield tint got damaged when i pulled the suction cup of my dashcam. the size is that of a 10 peso coin. it is behind the rear view mirror so nobody can see it, except when you are outside. my tint is the lightest 3M.
    question is, is there any diy process i can do to fix this? if not, should i leave it be or will it get bigger overtime? replacing the tint is my last option. Thank you!
    Quote Originally Posted by jujjay View Post
    ano damage? stained? o nagkaroon ng air gap?
    kung stained, try mo tanggalin lang ng wd40. kung may airgap, lalaki yan, but try to fix it first by plaining it down with a plastic putty knife or a credit card.
    Now, this got me worried....
    _/_/_/
    30.5K _/_/_/_/_/_/_/_/_/_/
    Jan 2003
    I don't think that will stick again without pulling one side of the tint to stick again. Your option left is cut out the damage portion so as not to enlarge the damage then you can have that specific place to stick on your dashcam.
    May 2016
    _/_/_/
    i dont think you should worry sir, it was dumb move on my part. hehehe.
    hingi po kayo ng retasong similar shade tint film na patapon na ng tintero. cut it to the proper size, and fill up the opening your suction pulled out. ask the tintero to do it, if you are un-able.
    the repair will probably not hold a suction cup anymore. but it should make the hole, less visible.
    or, you can ask the tintero to cut out some more, if not the entire film and start all over again.
    good luck.
    May 2016
    good luck.
    well noted Sir. will go to Banawe this weekend to check. Just want to check if someone can recommend a good shop for tints. thank you!
    _/_/_/
    Ako din. Suction type pa naman yung nakalagay saken.
    So if parked under the sun, remove the mounting muna?
    hindi ko na tinatanggal yung mount ko bro, ok pa naman. yun nga napaka-bihira ako mag park sa oven este open pala
    Jul 2011
    new tints, meaning you just had it installed?
    if so, may tendency talaga na sumama sa suction cup yan,
    hayaan mo muna dapat matuyo ng husto yung tints.
    i also have 3m tints, 4 years already, may dashcam din ako,
    and also before, phone mounts. ilang beses ko na nilipat lipat sa windshield,
    ok pa naman.
    unless pag nagtatanggal ka ng suction, inuunlock mo nga yung locking mechanism,
    then todo sa paghila ng suction, may suction padin kasi yun kahit naka disengage na.
    thus, sasama.
    what i do is, unlock the suction mechanism, then pry mo sa isang side nung cup
    hanggang magkahangin na yung ilalim, then kusa na syang bibitaw.
    regarding sa problem mo na ngayon, try mo flatten ulit yung film with a card,
    carefully, baka magkafold naman yung film pag binasta basta hagod lang.
damaged tint due to suction cup
