Results 1 to 10 of 17
- Apr 2009
- 272
April 6th, 2016 02:50 PM #1I replaced my old stock wiper with an nwb although there are improvements but i still see that it does not wipe everything to the side may natitira pang wet marks during rain and it still give light scratches to my windshield. What could be the problem kaya?
April 6th, 2016 02:54 PM #2
- Apr 2009
- 272
- Jul 2013
- 2,450
April 6th, 2016 03:04 PM #5NWB is the stock wiper blade of some Toyota models (ours is Innova).
Try checking the windshield itself if there are any imperfections or watermarks/waterstains.
- May 2015
- 32
April 6th, 2016 03:18 PM #6
April 6th, 2016 04:00 PM #8
You have to set the edge correctly(its probably twisted)...its not plug and play. I had the same issue a few months ago. Make sure you have water sa washer fluid tank
April 6th, 2016 04:02 PM #9
April 6th, 2016 07:30 PM #10
wala ng remedyo..if you are on a tight budget replace the spring. check casa kung meron kung wala remove the wiper arm spring as your sample. medyo time consuming nga lang. hanap ka either sa banawe, sa 10th ave kaloocan or T. Alonza manila. look for retail stores selling motorcycle parts, auto supply, industrial parts etc... when buying make sure the spring size and tension are similar to your sample. goodluck
Automatic po Sir
