Results 1 to 10 of 17
- May 2015
- 32
April 6th, 2016 03:18 PM #1
April 6th, 2016 04:00 PM #3
You have to set the edge correctly(its probably twisted)...its not plug and play. I had the same issue a few months ago. Make sure you have water sa washer fluid tank
April 6th, 2016 04:02 PM #4
April 6th, 2016 07:30 PM #5
wala ng remedyo..if you are on a tight budget replace the spring. check casa kung meron kung wala remove the wiper arm spring as your sample. medyo time consuming nga lang. hanap ka either sa banawe, sa 10th ave kaloocan or T. Alonza manila. look for retail stores selling motorcycle parts, auto supply, industrial parts etc... when buying make sure the spring size and tension are similar to your sample. goodluck
- Oct 2009
- 2,271
April 8th, 2016 05:18 PM #6kung maganda pa wifer arm mo .at sadyang makinis pa talaga ang windshield mo.
kahit local yan wifer blade mo.maganda parin ang hagod nyan.
- Sep 2009
- 387
April 8th, 2016 05:42 PM #8Leaving the wiper springs on a stretched position damages the spring. You will usually observe this on open parking spaces. People do this to preserve the wiper blades.
April 8th, 2016 08:14 PM #9
April 8th, 2016 09:17 PM #10
most wipers deteriorates overtime even they just sits there during the entire dry season no matter how or what we do just to preserve them at least. now here comes the rain then, bam! i need a new pair of wipers,,,again. though a bit of elbow grease cleaning the blades or windshield does the trick sometimes.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
