Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 91
    Jul 2011
    #21
    Don't know if still a problem now pero I can't access Tsikot thru Tapatalk & Forumrunner earlier.
    Tapos kahit dito sa site di maaccess PMs
    I can access tsikot using tapatalk. Older version nga lang.
    Sent from my HTC One S using Tapatalk 2
    #22
    Quote Originally Posted by LiempoBoi View Post
    Gumagana na ulit ngayon. Kanina kasi hindi eh.
    Sent from my 3210 using Tapatalk HD Premium
    Mar 2013
    #23
    Tip to access the forum.
    1. Click the Login button. This will redirect you to Tsikot Hub Automotive Social Network - Powered By phpFox
    2. Click the Forums Login
    3. Key-in your tsikot credential
    4. Click Forums. You will then be redirected to tsikot.com/forums after selecting a thread.
    #24
    Testing testing...
    #25
    Mga mods/admin, I'm getting the following error message when trying to access some forums/posts:
    Error 406
    Generally a 406 error is caused because a request has been blocked by Mod Security. If you believe that your request has been blocked by mistake please contact the web site owner.
    Is there any reason for this? Help please.
    #26
    Hello Altis, can you post here the link to any post or thread that is throwing off a 406 error so we can investigate further. Thank you.
    #27
    Quote Originally Posted by tsikot View Post
    Here you go:
    http://tsikot.com/forums/politics-ec...dulous-100427/
    #28
    #29
    The "Dasmarinas bans DOTA" thread, too.
    Asked Monseratto, both threads made on Tsikot Mobile.
    I notice that posts made via PC, punctuations get excluded from the automatically generated thread address, while in the offending posts, the mobile app keeps them... and since browsers can't understand web addresses with punctuations...
    #30
    Quote Originally Posted by Altis6453 View Post
    I can't access this thread also. But how come some other tsikoteers can?
    #31
    same here on the Dasmarinas DOTA thread.
    #32
    tapos ako i always experience yung message na "This forum requires that you wait 30 seconds between posts" even though wala pa akong na post.... Tapos pag ni-repost ko, double post na ako.
    You can access the thread using the Tsikot Forum Mobile app on your gadgets, but cannot access from browsing on the PC...
    #34
    We are looking into this strange problem. I temporarily archived the threads until we sort this problem out. Our apologies to the thread starter.
    #35
    Same here. Madalas ako double post dahil nung "This forum requires that you wait 30 seconds between posts".
    #36
    I'm just new here and also encountered the same issue. Nagdouble post tuloy yun first post/reply ko
    Oct 2013
    #37
    Cannot access tsikot using internet explorer, sa firefox at chrome ok.
    #38
    Quote Originally Posted by vvti2.0 View Post
    Same with me Chrome ok, but Internet explorer has a glitch.
    #39
    ^^^switch to compatibility mode.
    Jan 2009
    #40
    Double-posts and errors. Has been going for months.
    Also, responding to posts or doing a search within the forums produce errors such as this:
    Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with vB_Model::getLoadQuery( = '', = false) in ..../packages/vbforum/item/socialgroupmessage.php on line 261
    Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery() should be compatible with vB_Model::getLoadQuery( = '', = false) in ..../packages/vbforum/item/socialgroupdiscussion.php on line 337
    I have to ask why these issues have not been fixed?
    Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with vB_Model::getLoadQuery($required_query = '', $force_rebuild = false) in ..../packages/vbforum/item/socialgroupmessage.php on line 261
    Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery() should be compatible with vB_Model::getLoadQuery($required_query = '', $force_rebuild = false) in ..../packages/vbforum/item/socialgroupdiscussion.php on line 337
Trouble accessing forums and PMs
