Some tips for travelers thinking of parking their cars at any of the NAIA terminals. First the common traits:
- All have overnight parking facilities, well guarded and secure, but open air.
- Rates are P50.00 per night
- I've seen long-term "parkers", esp at NAIA 3 where some cars have their "blankets" covering them.
- When you get in, just ask the guard for the overnight facilities and he'll direct you to the place. The guards on duty will get your vehicle make, model, plate no., name of motorist, no. of days you'll be gone, destination, contact nos. and signature.
- Keep parking stub for verification once you arrive and get out of the parking area.
Now for the issues:
- NAIA 1 & 2: ang layo ng parking! At NAIA 1, they'll direct you to Parking C, on the right side. Entrance to the airport's departure area is through a steep fight of stairs. No access thru the arrival area. Hassle upon arrival coz of the long walk to the parking lot.
- At NAIA 2, it's in Carpark 2, front of old Phil. Village Hotel (used to be in Carpark 1 but the guard said that watching over the cars was more difficult, hence the transfer to carpark2). Entrance to the airport is thru a steep flight of stairs from the parking lot to the sidewalk along the driveway, then another short walk to the arrival hall, then another steep flight of stairs to the departure hall. Accdg to the guard you can use the elevator at the arrival hall. In both cases (1 and 2), it's not advisable if traveling alone w/ huge check-in luggage. If you drop off a traveling companion w/ the luggage, puede yon, but be prepared for a long drive to make a u-turn back to the airport parking lot. Also a hassle upon arrival coz of the long walk to the parking lot.
- At NAIA 3, parking is to the farthest end of the lot, on the left if facing the airport. Be prepared for a long walk to the entrance at the far end of the arrival hall (to your right if facing the airport). At least if you have roller bags, walang problema. You can place the bags on the xray machines at the entrance and take the elevator or escalator to the check in counters. Most convenient when arriving, coz you can exit at the part of the airport that faces the overnight parking area. A short walk to your car.
Hope these tips help all those who are planning their trips, whether it's busienss or leisure.
Hmmm... There is also the Park N' Fly parking di po ba with shuttles to and from the airports.
