Results 1 to 8 of 8
- Aug 2013
- 38
July 20th, 2016 06:01 PM #1Good day mga sir. Gusto ko lang iclarify kung sa tranny nanggagaling yung whining sounds ng CRV 02 namin. Nagpareplace kasi ako ng surplus tranny tapos napansin ko na may whining sound kapag nakatigil kapag nasa park or neutral. Tapos bumabalik balik yung tunog kahit umaandar na. Smooth naman yung tranny no jerks and delays etc. Tapos ok naman yung atf level at bago pa.
Sa tranny ba to mga sir? Sabi kasi baka daw sa power steering pero puno pa yung power steering ko eh. Nakakakaba tagal ko na kasi pinroblema tog tranny ko.
Salamat sa magrereply!
July 20th, 2016 06:14 PM #2
fact
you are not sure whether it is the hydraulic power steering or the transaxle is the source of the noise.
to eliminate the possibility of the hydraulic p/s as the source of the noise, temporarily remove the p/s belt and replicate the driving conditions when the noise usually occur. if the noise is still present with the p/s belt off, then it is your transaxle
- Oct 2009
- 2,271
July 20th, 2016 06:46 PM #3manual ba or matic ang tranny.dati bang wala ung sound na yan bago mo papalitan ng tranny
- Aug 2013
- 38
July 20th, 2016 07:06 PM #5Thanks sa reply mga sir!
Matic 2-WD pala to boss. Actually 2nd palit na to, kasi yung unang sinalpak 5-speed kaya nagkaproblema sa sensor. Wala ako napansin na ingay dun sa una. Ngayong tama na yung tranny na ginamit, dun na ko may napansin. Wala din ingay dati prior to any tranny replacement
Could it be something sa mga belt? Pansin ko kasi na nagiiba yung pitch depende sa RPM kapag nirerev ko in park/neutral. Nagtataka lang ako na nawawala siya minsan while moving pero just for a few seconds
- Aug 2013
- 38
- Oct 2009
- 2,271
July 29th, 2016 07:26 PM #7
- Aug 2013
- 38
July 29th, 2016 07:42 PM #8Ganun ba boss. Sige ibalik ko sa gumawa sana hindi masakit sa ulo kailangan gawin salamat po
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
