Page 1 of 9 12345 ... LastLast
Results 1 to 20 of 179
    Dec 2014
    Noob question guys.
    What's the use of neutral sa AT and ano pinagkaiba nya sa Park?
    Thanks
    May 2012
    Pag nasa traffic or stop ang traffic light N for neutral lang,pag naka P or park ka at na bangga ka sa likod wasak ang transmission mo.
    Jan 2009
    Noob question guys.
    Thanks
    Pag neutral ata naka disengage sya sa transmission kaya pag naka neutral ka puede ka mag rollfoward o backward need mo apakAn ang brake o engage ang parking break. Pag naka park naka engage sa transmission kaya hindi gagalaw sasakyan yun nga lang pag nabangga masisira ang transmission ata
    Dec 2014
    Quote Originally Posted by jyg1995 View Post
    *jyg1995 thanks.
    Another noob question, yung mga kakilala ko lagi ako dine discourage to buy an AT car kasi daw di mo "mahihila" pag nasiraan ka. I don't if they're saying literally or may ibang meaning.
    But let's say di mo nga mahihila, base on your answer, it seemed like "mahihila/matutulak" mo naman sya paga naka Neutral? just like a manual transmission right?
    Dec 2014
    Quote Originally Posted by smuiv View Post
    hey thanks.
    So if naka "P" ka sa downhill or uphill without a handbreak may possibility rin na masira since naka engage sya transmission? and your car is moving forward / backard?
    Jan 2009
    *jyg1995 thanks.
    Mahihila mo naman o matutulak. Baka ibig mong sabihin pag nawalan o mahina ang battery. Ang manual mapapandar mo pa tulak lang at kandyot 😄 ang AT pag na dead na battery tulak na lang o tow
    Jan 2009
    hey thanks.
    Hindi sya masisira unless na binangga ka ng malakas ng ibang kotse. Kasi naka park ka nakakapit sa transmission di gagalaw sasakyan mo maski naka uphill o downhill
    P or Park in an a/t is the same as putting your m/t in 1st gear when it is parked.
    In P there is a stationary notched gear set that is engaged. This stationary gear set acts as a secondary park brake. So pag nabanga ka while in P, whether from the rear or front, it is this stationary gear set that will get damaged. Sira na din ang transmission most of the time because the force of the collision will pass from the wheels to the differential to the transmission planetary gears to this notched gear in the tranny.
    Apr 2010
    Mahihila mo ang A/T lalo na if may transfercase as in 4wd vehicles. Yung sakin nilagay ko sa Park, shift tcase sa Neutral and am on my way
    Does that mean it's better to keep the car at N when parked? Kasi kahit sa garage/parking may possibility ka pa rin mabangga.
    Oct 2009
    he he yan nga din iniisip ko..so ano ba tagala function ni P kung delikado din siyang gamitin.sabi nga nila ginagamit lang pag mag park kana, mag mabisa pang mag N ka nalang saka handbrake..kaysa P
    Kapag nabanga ka na naka P, mag slide ang tires sa pavement at hindi madadamage gearbox mo.
    You won't be able to pull out the key when you're in N.
    and it is there and called Park for a reason
    Feb 2009
    For most front wheel drive cars, the car rolls down when the front tires lose traction or if the front tire/s come off the ground if the parking brakes are not on. For FWD Subaru, the parking brakes are on the front tires so they should be firm against the ground.
    Feb 2011
    For those asking about towing or pushing the car from P. usually may shift lock ang mga AT na cars, disengage it, pwede ma matow yung kotse.
    Jan 2014
    Noob question guys.
    Thanks
    So it's not tiring to go from d to P in traffic situations
    and you can save gas by putting in N during heavy traffic
    and pagnagstall yung car(kung di minemaintain) lagay mo sa
    N para maitulak o maitow/hihilahin paakyat sa truck
    Feb 2009
    Be very careful with "full time all wheel drive" or honda's "rel time 4wd", they need to be on a carrier or the axles have to be disconnected to prevent transaxle damage
    Jun 2012
    Depende sa sasakyan. Ang montero pwede kahit pa nasa D or R. Haha
what's the use of "N" in a AT?
