Results 1 to 10 of 179
December 27th, 2014 12:11 PM #1
Noob question guys.
What's the use of neutral sa AT and ano pinagkaiba nya sa Park?
Thanks
December 27th, 2014 12:18 PM #2
Pag nasa traffic or stop ang traffic light N for neutral lang,pag naka P or park ka at na bangga ka sa likod wasak ang transmission mo.
December 27th, 2014 01:11 PM #3
Pag neutral ata naka disengage sya sa transmission kaya pag naka neutral ka puede ka mag rollfoward o backward need mo apakAn ang brake o engage ang parking break. Pag naka park naka engage sa transmission kaya hindi gagalaw sasakyan yun nga lang pag nabangga masisira ang transmission ata
December 27th, 2014 01:15 PM #4
*jyg1995 thanks.
Another noob question, yung mga kakilala ko lagi ako dine discourage to buy an AT car kasi daw di mo "mahihila" pag nasiraan ka. I don't if they're saying literally or may ibang meaning.
But let's say di mo nga mahihila, base on your answer, it seemed like "mahihila/matutulak" mo naman sya paga naka Neutral? just like a manual transmission right?
December 27th, 2014 01:19 PM #5
December 27th, 2014 01:21 PM #6
December 27th, 2014 01:24 PM #7
December 27th, 2014 02:27 PM #8
P or Park in an a/t is the same as putting your m/t in 1st gear when it is parked.
December 27th, 2014 03:15 PM #9
In P there is a stationary notched gear set that is engaged. This stationary gear set acts as a secondary park brake. So pag nabanga ka while in P, whether from the rear or front, it is this stationary gear set that will get damaged. Sira na din ang transmission most of the time because the force of the collision will pass from the wheels to the differential to the transmission planetary gears to this notched gear in the tranny.
- Apr 2010
- 742
December 27th, 2014 03:20 PM #10Mahihila mo ang A/T lalo na if may transfercase as in 4wd vehicles. Yung sakin nilagay ko sa Park, shift tcase sa Neutral and am on my way
Heard through the grapevine that the Atto 2 is going to be released next. The most likely date is...
BYD Philippines
