Results 1 to 10 of 10
    Feb 2003
    hi peeps car is toyota vios, kaka 1 year pa lang last week and 4 thou kms pa lang tinatakbo...ndi naman ako clutch driver.... and i notice recently that after driving view kilometers ( the engine gettin hotter), nag sq squeak yung clutch ko kapag binibitaw...
    bakit ganun? ,....any suggestions?... or meron na kayong same experience katulad sa akin... thanks
    Jan 2004
    Hindi kaya dahil di masyadong nagagamit? Masama rin yun.
    4 thou for a year is too low.
    Although I would not think this is the direct cause. Could be a lemon. Wala na bang warranty?
    Feb 2003
    meron pa naman 3 years, 100 thou kms...
    by the way masama ba talaga pag ndi gaano nagagamit ang car... at least kun once a week i-start then patakbuin ng few kms. oks na diba?...
    Creates a sound after depressing the clutch pedal or while engaging clutch?
    Try nyo spray ng WD40 dun sa springs ng clutch pedal. Pag hindi nawala, regrease clutch cable if its cable operated.
    Feb 2003
    it creates a sound when depressing the clutch pedal when the engine is hot.... pero kapag malamaig ang engine wala itong sound...medyo weird noh ?...
    yup, cable clutch ang vios, pero i'm wondering kun bakit kapag mainit lang ang makina or running it around 8 kms. tsaka lumalabas yung ingay, and it only happened recently...
    Maybe engine heat dries up the the lubrication inside those cables? Re-greasing it would be an alternative way. Or try wrapping an electrical tape or some tape that could provide better insulation from heat around the cable exterior.
    Apr 2004
    hmmm.. hindi kaya dahil gawang thailand ang mga vios..i've heard made in thailand vehicles have inherent weaknesses.. quality control is one of them..
    my 2 centavos..
    Feb 2003
    o nga eh, by the way sir ungas, how about kun WD40 ko yung clutch cable? is it ok...or kailangan grease talaga?...
    You can use WD40, but it will dry up more faster than grease.
    Had the same problm with my Honda Civic.
    While the car is parked, try and trace on what
    part in the engine it is coming from. I traced
    mine inside a rubber boot in the transmission
    (rubber boot had a slight tear). Sprayed WD40
    inside but after a few week later, it squeeked again. Put some Singer oil in it and its been
    quiet eversince. Try it.
vios, squeaking clutch after a year
