Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Apr 2006
    hi guys -
    just want to ask. what i do during stop-and-go traffic when i want the car to move just a few meters/feet is to bring the clutch to it's working level without applying gas. when i want to stop, i just press on the clutch and the break. is this a good or bad practice? should i use the usual way of applying a little gas to move? is this fuel-saving?
    thanks.
    actually, walang problema dun, as long as di mo ibababad. put it in neutral kung nakahinto ka na...
    Sep 2006
    oo ok lang yung. basta din wag mong hayaang mag-engine knock.
    Wala naman wear sa clutch when it is fully depressed. Wear occurs as you transition from fully depressed to fully engaged.
    Aug 2006
    makisakay na din..
    ok lang ba na before reaching the traffic, switch na to neutral ang kambyo? ganun kasi ang ginagawa ko, esp during stop light...ano kaya effect nun?
    Sep 2006
    pag walang engine brake, cyempre more effort yung brakes..
    Quote Originally Posted by buraot View Post
    makisakay na din..
    Yun din ang ginagawa ko. Normal naman palit ko ng brakes. Naglast naman ang tranny ko. 169k na odo ko. Although, nagpalit ako ng gears ng 120k (2nd gear).
    Aug 2005
    Oks lng yan pre..
    ganyan din ako..
    Basta wag lang clutch driver..
    Pag stop light I dont change neutral kasi wlang engine brake.
    Quote Originally Posted by wewoy_romero View Post
    hi guys -
    thanks.
    yan din lagi ko ginagawa!
    ang alam ko ok lang ung ganun basta wag lang mag bababad ng hafl clutch!
    Jul 2006
    Quote Originally Posted by finchy18 View Post
    Oks lng yan pre..
    ganyan din ako..
    tanong po, anu po ung engine break?
    Aug 2005
    Quote Originally Posted by sirmykel View Post
    hi bro..
    is your car a/t or manual?
    I think its more applicable in manual ..
    makisakay na din..
    ako din ganyan, kapag malapit na neutral + feet off the gas and clutch then glide while gradual braking (yun sobrang hina) para sakto lang hinto sa traffic
    Aug 2006
    Quote Originally Posted by Vinsanity View Post
    ah, ok lang pala un...salamat...
    Jul 2006
    hi bro..
    manual po ako sir
    *topic
    ganun din gawa ko, pag malapit na stop neutral na them brake-brake-brake na lang
    fine and good as long as gradual ang release ng clutch and
    no excessive vibrations occur. remember mas mahal ang engine
    repair compared to drops of fuel.
    while braking, engaged ka pa rin sa huling gear mo
    bago mo i-neutral.
    Sep 2006
    Engine brake is the "force" that keeps your car from free wheeling dahil engaged ang transmission.
    Kaya sa mga mall parking na matarik (e.g. Shangri la) may mga sign na "Stay on first gear" This important lalo na sa pababa, para hindi bubulusok sasakyan mo kahit di mo tapakana ng brake.
    Note: Excessive engine braking (hard engine braking and/or prolonged engine braking) can damage your engine and transmission. Kaya dapat laging naka-alalay ang tunay na brakes.
    Quote Originally Posted by Picard View Post
    ganun po ba? Ako kasi kapag pababa, neutral na then alalay sa brakes para di masyado mabilis.
    Aug 2006
    paps, delikado ata ang ganun, ah...
    Sep 2006
    it's a no-no po..
using the clutch in stop-go traffic
