Results 1 to 9 of 9
    Nov 2003
    Hi, sa mga naka lancer (2004-2005) mx, have you had any problems with your cvts? also, what maintenance need to be done for cars equipped with this? thanks!
  2. #2
    just be sure you use cvt fluid not atf!
    Nov 2003
    i think on lancers, the cvtf and atf are the same thing. i could be mistaken but when you ask casa what fluid they use on the cvt's of the lancers they say just the regular spII/spIII fluid of mitsu.
    check to be sure imo.
    Jan 2009
    siguro mas safe to use CVT oil for CVT tranny. sa engineering design you have to do based on specs kasi pinagukulan yan during design. kaya risk mo if you use non-standard specs.
    Check with what the manual recommends and stick with it.....
    7505:bravo:
    Aug 2004
    Quote Originally Posted by speedyfix View Post
    I think that's about right. Mitsu's CVTs use a conventional torque converter, so the fluid requirements should be the same as a regular automatic.
    Nov 2003
    yeah, buti nga its the same. makes servicing it much easier.
    Oct 2008
    Hi,
    What are the normal intervals for CVT fluid replacements? I have a 2005 GLS. Thanks.
Lancer CVT, Problems Anyone?
