Results 1 to 2 of 2
    [SIZE=5][SIZE=2]May bago akong problema sa INNOVA AT . just today, nong nag start ako ng engine for 5 mins, pag move ko ng transmission to R (from P) may tunog ng TUG sounds (may naramdaman ako sa break pedal ko during adjusting the transmission from P to R)[/SIZE][/SIZE] then di po nag reverse ang kotse then binalik ko sa P. pag R ko ulit another TUG sound.. di rin nag atras then try ko ginawang D to 3 to 2 di talaga gumalaw ang kotse kahit i accelerate ko (with handbrake down.) para syang naka neutral, Off ko ang engine then Start ulit. yun nag move na lahat.
    ATF changed last aug 2010.
    Ano po ang problema nito anyone can help me plssssss...
    Dec 2010
    A vehicle not moving in reverse or any forward positions and the harsh engagement with the "tug" sound you heard may indicate clutch or other internal and external component malfunctions. Start by checking fluid level and condition and proper cable adjustments then have it scanned for possible PXXX codes.
    What you felt on the brake pedal was the abrupt engagement; the transmission wanting to "reverse" itself uncontrollably then losing its hold.
    Both mechanical and electrical tests should be performed. Baka next time it happens, di na talaga gumalaw yung kotse.
TUG sound then no function R or D Innova AT
