"Tranny"? Di ba ito yung asawa ni Lolo?![]()
One of the problems here, kahit sa Banawe, bibihira yung marunong talaga sa AT. Yung iba nga, di alam kung ano ibig sabihin ng shift solenoid or TCM, kung ano-ano pang sinasabi. Ang sarap bigwasan....
Most gasoline service stations can only change ATF, tapos drain hole lang yung tatanggalin. They dont even dismantle the pan.
uhm ok, since im hearing a lot og AT problems, any thoughts on my honda city i-dsi, sort of lifespan nya, im such a noob even bought the car kahit d pa ko sanay mag-drive last year, im also kinda scared asking this question... sana positive maging replies sa tanong ko, hehehe, TIA
A transmission has no 'lifespan'. Just maintain it properly following manufacturer (not dealer) recommended maintenance procedures written in your owner's manual.
The dealer's maintenance recommendations sometimes call for uneeded work (to generate themselves extra income).
Ano bang difference ng power mode at OD off sa pajero field master? Sabi kasi sa manual use when you need extra power for overtaking and goin uphill. So for example paakyat ako baguio dapat ba sabay sila o isa lang at alin sa kanila ang isi switch?
the function of the overdrive (OD) button have been discussed extensively here in tsikot, please do a search.
the power mode simply instructs the transmission to upshift at a higher rpm, which gives the car more power when overtaking.
when going up baguio, putting your shifter at position D is enough.
Ironically, you turn OD off when you need extra power for overtaking ang doing uphill. Confusing? Just check the other threads. hehehe.Sabi kasi sa manual use when you need extra power for overtaking and goin uphill
Basta O/D, up to 4th gear
O/D off, up to 3rd gear only.
Power mode is as defined by boybi
HOLD - holds on to gears longer to avoid 'gear hunting' on long ascents/descents.
