Results 1 to 10 of 28
- Feb 2003
- 1,038
April 20th, 2016 09:37 PM #1Sir saan casa yan? Buti pumayag na sa labas ka magsource ng parts..meron din ba sya (Fullness) parts for Honda?
April 21st, 2016 12:46 PM #2
April 22nd, 2016 01:35 PM #3
- Jan 2017
- 6
January 14th, 2017 05:12 PM #4
- Apr 2017
- 4
April 27th, 2017 09:43 PM #5ung honda civic vti AT 2000 model ko nmn mataas na rev pero bagal ng acceleration and worse tagal na kumapit ng reverse kaya problemado ako once nasa u-turn slot ako na masikip.. anyone who could help me with this? bago pa lang kasi ako nagkaroon ng kotse.
- Mar 2005
- 354
April 28th, 2017 08:31 PM #6Tanong lang...
Pwede ba ipalit transmission ng 1.6 engine sa 2.0?
Say for example Mazda 3 1.6 to Mazda 3 2.0 with same year model.
Thanks
- Aug 2017
- 3
August 6th, 2017 09:50 PM #7Mga sirs:
Meron akong 2010 Chevrolet Captiva AT 2.4 Gas Engine.
Mga a month ago gumagana pa sya sa D mode pero kapag nakatakbo na nang malayo ayaw na, pero sa Manual mode number 1 and 2 ok sya...Kaya I was able to bring it to Chevrolet -- and they said na transmission valve assembly daw...pro bukod sa super mahal eh wala silang available parts...two weeks after, kahit sa manual mode 1 and 2 ayaw na...hindi na tumatakbo..pero reverse walang problem..nagrereverse sya....
Ano kaya po sira nito? I tried to sa mechanics na recommended dito sbe nun isa computer box...sa thunder 38k daw..so nagtry ako sa RAMSA at sbe hindi daw sira...I tried ulit sa isang mechanic sabi naman sa wiring at fuses pero hindi rin sure...sa fuses walang sira..hindi ko na inattempt sa wiring...
Help po mga sirs..baka may idea kayo or recommendation...
Many thanks in advance!
- Aug 2017
- 3
August 29th, 2017 02:18 PM #8Please help. My Montero sport GLS V had a problem, I was cruising around 100kph when suddenly it jerks and the Transmission indicator shows blinking "D" and started loosing power. tried selecting on manual mode it stays on 3 when i select i again to "D" the same problem exist anyone experience this? . thanks in advance
- May 2011
- 481
August 31st, 2017 08:04 AM #9
- Apr 2018
- 15
May 2nd, 2018 05:50 AM #10Pa-help naman po, naexperience ko po kasi na hinde ako maka-shift ng gear kapag naka turn on yung engine. Pero pag naka turn off naman po, nakaka shift ako sa kahit anong gear. And i noticed po na biglang malambot apakan yung clutch ko, parang wala ako inaapakan. i checked on the clutch fluid sa may engine, wala ng laman.
Ano po bang fluid pwede ko gamitin? wala din naman pong signs ng leak sa may engine. Ano po kaya problem ng FD ko? and baka meron po kayo ma-suggest na reliable mechanic, makati area po sana.
Honda Civic 06 1.8S Manual po pala yung ride ko.
Salamat po mga ka-tsikoters.
VinFast VF 3
