Results 1 to 13 of 13
    Feb 2006
    after running my engine and already in its normal operating temperature, my reverse becomes cranky, rinig mo yon gears while going to reverse, going to 1st gear is not as smooth as the from a cold start engine.
    clutch disc replacement will fix it?
    How long would it take?
    estimate of the cost
    Nov 2003
    the esi clutches really have a tendency to crunch going into reverse. try replacing the gear oil and see if that improves it a bit. or try to double pump the clutch before putting it into reverse.
    Feb 2006
    mine is a 2 door hatchback with stock engine, ganon rin ba talaga ang clutch non? dati kasi di naman. or maybe i just spending more time na ngayon sa car kaya ko feel na iyon, hehehe!
    Will try to change gear oil, tagal na rin siguro di pa change yon, if palit ba ng clutch disc, engine will also stay at the engine bay just like changing timing belt?
    Nov 2003
    yup ganun din.
    unless you need to open up the engine, all work to it can be done with the engine in the car.
    Oct 2005
    mine is also a 2 door hatch 95 model. i'm having the same nuissance parekoi...pero nasanay na ko at hindi na rin masyado nag-ga-grind yung gears while shifting paatras. inaapakan ko lang ng maigi yung clutch pedal. kakapalit ko lang ng clutch kit last november (bought it last september) so kampante akong hindi clutch problem ito. pero i didn't try changing the gear oil... malamang dun nga 'yon. pero smooth naman ang shifting ko in all forward gears kaya hindi ko pinapansin...malapit na rin kasi ako pa-100000km checkup so baka isama ko na sa checklist ito kapag dumating ang time na yun. when was the last time you changed your clutch sir?
    Feb 2006
    AFAIK, di pa napapalita ang clutch disc nito, minana ko lang kasi ito sa uncle who passed away. kaya di ko masyado alam ang history ng maintenence. OK lahat ng forward gears nya, la problem, smooth pa rin. masasanay na rin siguro ako. minsan flawless entry sa reverse. paiba-iba nga kaya let it be na lang siguro, kasi ubos na savings ko kakapagawa ng kotse. sana wala na iba sira. kundi, iiyak na talaga ako. huhuhu!
    had the timing belt changed na. 95,000KM. Non nakita ko yon belt, ok pa naman, tatagal pa siguro ng another 10,000KM, takot lang ako mas malaki gastos kung abutan ng patid. Hirap na.
    Oct 2005
    Quote Originally Posted by mr._bator
    sir OT lang ha...gusto ko lang talagang malaman...matagtag ba ang ride mo?
    Feb 2006
    di naman matagtag ang ride. smooth din. ano problem kung matagtag ang ride?
    gumagamit pa ba ng clutch cable ang civic'94?
    ask lang ako
    Oct 2005
    mr. bator: it's not related to your problem sir. matagtag kasi ang ride ko e.
    sir baludoy: sa 95 model hindi clutch cable. clutch fluid sya afaik.
    same as mine... pero di naman lagi. tingin ko dapat apakan lang ang clutch mabuti.
    Quote Originally Posted by umzzzzz
    baka pinapapasyal ka na kay zee or cruven. :D
    Feb 2006
    fluid ang 94, kahit mga later models, fluid na rin.
    this is a tranny oil problem, malamang hindi pa or matagal na napalitan tranny oil mo. I had this problem in my previous car, at cold start ang hirap ipasok from 1st to second pero after a few minutes okay na, when we drained the tranny oil grabe ang lapot, I just replaced the tranny oil and everything worked out fine.
    Maybe that will solve your reverse problem too.
ano problem ng 94 civic clutch ko?
