when should we change the transmission oil of our car. mine is lancer 97 GL.
Magpapalit na din ako ng transmission fluid sa next change oil ko. Ang napupusuan ko ay Royal purple.
recommended intervals are between 20-40k kms. the sooner the better though.
pano po kung napalitan na ung mga kailangan palitan sa clutch pero mabagal pa rin pag paakyat ung kotse, ano pa po ang pedeng cause nito?
thanks!
ano yung mga napalitan? sino nagsabi na kelangan palitan?
baka naman wala sa transmission yung problem and it's with the engine na.
Time to change Automatic Transmission Fluid in my Mitsubishi car with Tiptronic (+/-) semi automatic transmission and 90T kms mileage.
The sticker in the hood recommends Diamond SP II ATF. Cant find any store with Dia SP II ATF, not even on mitsubishi exclusive parts stores.
Some says a Dexron III ATF will do, but i dont want to mess up an expensive tranny by putting a wrong ATF.
Does anyone knows a suitable replacement or have similar ATF specs but used different ATF brands with positive results.
Your advise is anticipated with thanks.![]()
royal purple max atf multi spec meets mitsubishi SPII and SPIII requirements.
rp atf is 700/lit, you will need between 3-4 for the drain/refill, plus labor.
sir, magkano ba replace ng transmission oil for toyota altis using RP? medyo matigas na kasi yung clutch ng altis ko. just finished my 35K PMS last saturday sa casa (under warranty pa kasi).
pag matigas na ba yung clutch ano possible na sira dun? suggest kasi ng casa sa akin ibaba raw yung transmission to check ano problem ng transmission ko. hay, hindi ko na pinansin suggestion nila.
thanks.
^^imho, pag matigas ang clutch, sa hydraulics yan... either sa master or secondary clutch. when was the last time you changed/drained your clutch fluid?
rp gear oil is 800/quart. it won't make the pedal any softer but it may make shifting easier.
pag matigas yung clutch pedal that normally means kelangan na ibaba yung tranny to check the pressure plate assuming there are no leaks sa clutch master/slave.
ilang quart ba ang kailangan for toyota altis if palit lahat? this will be the first time na magpapalit ng oil yung altis namin (nasa 35k palang yung odo).
possible ba na may sira na yung tranny even if nasa 35k palang yung takbo? assuming normal driving habit yung paggamit ng sasakyan?
what other transmission oil would you recommend for toyota altis (2007 model)? yung affordable price na sulit.![]()
you need about 3 quarts.
pwede sya masira depending on how you use it. kahit normal driving lang but babad sa clutch pwede mangyari.
