Results 1 to 19 of 19
    Mar 2003
    ano bang transmission and differential oil ang dapat gamitin sa hyundai H100? simula kasi ng nabili namin yung sasakyan hindi pa napaplitan yung mga yon.
    Common gear oils used are 90 grade oil. Except for LSD equipped rear differentials which require atleast GL-5, if I recall it right.
    Mar 2003
    ok kaya kung sa caltex expresslube ako magpapalit ng trans & diff oil. siguro naman alam nila kung anong dapat na gamitin na grades.
    Yes, they should know what kind of different gear oils are available in the market. Just make sure their mechanics are well competent with their services.
    Nov 2003
    the caltex thuban 90 grade gear oil should be good for most trannies unless otherwise states.
    some lsd's will require hypo gear oil
    Mar 2003
    paano ba malaman kung may LSD ang isang vehicle?
    Aug 2004
    para malaman kung naka lsd ang auto mo. if rear drive yan. jack mo parehas yung 2 likod na gulong mo then try mo paikutin yung isang gulong mo tpos kung same direction yung ikot nila that means naka lsd ka pero kung di cla same direction it means hindi naka lsd.
    Mar 2003
    kaya ko naitanong kasi nung napapalit ako ng crossjoint nagtaka yung mekaniko kung bakit mahirap ikutin yung gulong ko sa likuran(isang gulong lang ang naka jack) akala niya wala ng gear oil pero pinacheck ko sa gas station puno naman daw may lsd kaya ito?
    Aug 2004
    try to jack parehas pra mas sure ka.
    Mar 2003
    kanina ko lang na i-jack yung both wheels kasi nagpa greasing ako and may LSD nga ito. kasi nung inikot ko yung gulong pareho yung direction ng ikot nila! so anong gear oil ang dapat kong gamitin?
    Dec 2002
    For LSD, use LS gear oils like:
    Mobil LSA 90
    Castrol hypoid LS
    Think Caltex also has in some express lube stations.
    Mar 2003
    sa website ng caltex may nakita akong caltex gear oil LSD and caltex thuban GL5 EP ok na ba ito? yung gear oil LSD for the differential and yung thuban para sa transmission. and btw ilang liters ba usually nagagamit for the diff and trans? and how much ang per liter ng mga oil's na ganito?
    Dec 2002
    jeff,
    You can use the caltex LSD for the differential but suggest you use a Sae90 GL4 gear oil for the manual transmission.
    Amount needed differ, usually about 2-3L per part. Lsd prices range from P250-350/L.
    Mar 2003
    so for the transmission dapat gl4 and sa differential gl5 ang rating ok na?
    Dec 2002
    Kung LS ang diff, dapat LSD oil and gamitin. Kung open diff, puwede na ang GL5 oil.
    Aug 2004
    tnung lng po bakit sa isuzu manuals nabasa ko na pagnagpalit ka ng gear oil. ang kailangan mong ilagay ay engine oil hindi gear oil?
    Dec 2002
    Some isuzu, honda models specify engine oil for their manual transmission.
    But have to use GL5 gear oil for rear differential.
    May 2004
    up ko lang. i have a 99 trooper 4jg2 engine. rear differential e LSD na. nakalagay sa manual e GL-5 dapat gamitin. front differential ba e open? kasi nakalagay sa manual e GL-5 din gamitin? post na rin kung san merong okay ang price. wala kasi sa shop na pupuntahan ko eh.tia
    Bro,
    If you can find a 80W-90 rating oil it will be sufficient for its purpose.
transmission & differential oil
