My friend have a 93 Corolla A/T 128KM and ang problem is ayaw nang umandar nung auto kahit anong gear. Last two weeks kasi pina drain yung ATF and it was working fine then. Nag start yung problem nung paminsan minsan ayaw pumasok sa reverse ngayon pati sa drive ayaw na. At ang isa pang problema is may nakitang leak after two weeks nung ipa drain yung atf. Do you think ang problem is nauubusan nang atf kaya ayaw pumasok ng tranny? and sa cavite area kasi siya may recommended ba kayong mechanic na maayos gumawa para ma pa check yung leak?
