Results 1 to 11 of 11
    Need help mga Sir. Recently (Jan 21) my CRV 99 1st gen cannot shift into "P" mode gear. Dulo na sya pero naka Reverse "R" indicator pa din at yung knob or gear stick parang maluwag. I removed the cover ng manibela to check wala naman sira sa mechanism ng knob. Ok naman ang ibang gear R - N - D4 - D3 - 2 - 1 gear mode.
    Please help. ANo po bang deperensya ng ganitong klase.
    Salamat ng marami.
    you may opt to bring the car to you trusted mech shop to get it hoisted up for proper checking
    Check mo muna ATF fluid baka low level or marumi na dahilan rin ng hard shifting.
    Feb 2009
    Quote Originally Posted by bushoTATO View Post
    Salamat ng marami.
    check the bushing at the shifter cable end where it meets the shifter arm on the transaxle. usually, this plastic bushing or sleeve breaks down in time and is not able to push the arm to its farthest position P
    Mga Sir na solved na nga pala itong problem ko. We replaced the shifting cable because it is already worn out. We noticed the stranded wire on the end is loosing I dont know the reason "parang lumambot yung stranded wire" that is why hindi proper ang push and pull ng wire thru shifting. Anyway 3 weeks leadtime ang ordering ng genuine parts sa Honda Sta Rosa Laguna. The part Nbr is 54315-S10-A82 Wire Control it cost Php 9,700+.
    Although naghanap ako somewhere ng replacement and cheaper part pero hindi available so no choice I go for the genuine parts.
    Thank you very much for all the replies.
    need help too, crv 2000 a/t
    ayaw mag shift sa D (drive). neutral, reverse at park lang siya. what could be the possible problem. TIA
    Jul 2010
    Quote Originally Posted by phezthie View Post
    baka pareho lang kayuo ng problema at solution ni broTS?
    ok naman sir yung cable. actually, nag start lang yung problem after mag rewire ng alarm sa may under dash fuse box. after non, ayaw na pumasok sa D ang shift cable.
    still hoping for someone who could help...
    Your CRV model has column shift right? The problem may be electrical since you said that it only appeared after some rewiring under the dash (although the cable would also be suspected of being unintentionally tampered while rewiring). I suggest contacting the casa even thru phone to ask for advise first.
    Quote Originally Posted by CivicVTi View Post
    many thanks for the reply, i think i found/solved the problem.... indeed its the cable. but i did a little bandaid "pansamantagal" fix and hopefully it will work for a while...
Tranny Problem - Cannot shift gear into Park "P"
