Results 1 to 4 of 4
    Apr 2010
    i wanna change the shifter on our terrano. because its a converted one so the button is on the right side it looks like this:
    any ideas? thanks amigos.
    Nov 2006
    Quote Originally Posted by ParticleX View Post
    the easiest way other than looking around for a compatible shifter is to have the entire shift rod cut at the bottom, turn it around then re-weld...of course by a reliable smith
    Some RHD shifters can be turned around (to LHD config) simply by removing the lock screw and rotating the sliding rod inside.
    Apr 2010
    i cant seem to find a screw in the shifter..
changing a/t shifter?
