Results 1 to 10 of 37
    Dec 2003
    imo i prefer timing chain like sa bimmers compared to timing belts of my previous civic. 1 less part to worry about hehe
    Jun 2005
    Timing belt is used in mostly high reving engine because of smoothness in transmitting rotation from crankshaft pulley to accessory drives like camshaft. Its a lot more quieter than the timing chain or timing gear, and that is also the main reason why luxury cars like lexus, infiniti, acura or cadillac uses them. The trade off is that you have to have it replace when it reach a certain mileage (km) or hours of operation.
    Timing chain is used in medium reving engine like Sentra, or other small block engine. They are a little bit noiseier than than the belt, but they last a lot longer, specially if proper lubrication is maintained.
    Timing gear is used mostly on diesel engine due to high torque that is being generated by the engine, plus it can take a lot of punishment before breaking. Most big block engine like Tractor trailer (18 wheeler) or electric generators which can run forever as long as it properly lubricated.
    Not many car manufacturer is using timing chain anymore due to fact that customer like you and me, like the quietness of our driving. It only hit us on the back side of our cranial when it due for replacement. It cost an arm and a leg to get replace.
    Quote Originally Posted by lakay
    well said
Timing Belt vs. Timing Chain vs. Timing Gear
