Results 1 to 7 of 7
- Nov 2009
- 21
January 20th, 2010 08:48 PM #1Nasa casa po right now yung car ko Nissan Sentra GX 1.3L A/T. Isa sya sa mga minalas na nabaha, naroad-test na nila yung oto pero may problem na lumabas. Erratic yung idling (minsan napakataas nung stick sa gauge minsan naman parang nagpu-pump sya), other problem mahina humatak.
Diagnosis: Throttle daw yung cause nung erratic idling at kailangan daw itong palitan, yung walang power (hatak) na-trace nila sa TCM (transmission control module) at kailangan din daw itong palitan. They said that they already cleaned the throttle assembly prior to road testing. Napalitan na rin lahat ng fluids as in ready for pick up na yung oto nung biglang lumabas tong dalawang problem na to.
Ask ko lang mga bosing kung kaya pa bang gawan ng paraan o marepair yang dalawang parts na yan? Bago ako magdesisyon na magorder ng bago. May kamahalan din kasi eh, yung Throttle more than P20k, yung TCM around P30k din.
Pa-post na lang po kung saang repair shop kaya iparepair 'to. Baka kasi simple sensor or solenoid lang ang damage pero pinapapalitan na yung buong throttle assembly at TCM.
Please help! TY
January 20th, 2010 09:03 PM #2
You can try contacting this guy...
http://www.sulit.com.ph/index.php/vi...modules+repair
He repairs electronic parts of flood damaged vehicles. Medyo harang nga lang ang presyo nya but you can try to inquire first.
Balitaan mo kame kung ano nangyari.
- Nov 2007
- 246
January 20th, 2010 09:22 PM #3yung TCM hindi mare-repair kasi daw madami IC. Ganito nangyari sa suzuki ko. nalubog din sa baha pero half lang ng doors water level pero inabot pa rin ECU. yung compu ng engine narepair sa Love electronics(1k pesos) pero yung TCM hopeless daw coz of the ICs.
Nag-order ako kasa, 3wks. 28k damage.
Tumatakbo na pero mataas ang idling, nasa 1800rpm. dinala ko na lang sa suki mech, binuksan throttle servo, di naman daw damaged so kabit uli.
voila ganda na uli takbo, back to normal na menor.
I doubt kung nagbubukas kasa ng mga assemblies, palit lang ng palit alam nyan. starter ko pinabuksan ko din sa mekaniko, puro putik at kalawang.
kung kasa ko pinagawa yon palit agad recommendation nila doon.
- Nov 2009
- 21
January 20th, 2010 10:00 PM #4*Babnoy - thanks sa link sir, try ko kontakin to. Ang worry ko lang actually is, kailangan kong i-pullout yung oto sa casa para mapagawa sa labas, di naman kasi pwedeng yung part lang na sira ang ilalabas ko kasi wala silang pagtetestingan. Ang siste pag di nagawa ibabalik ko na naman sa casa at pipila na naman ng panibago yung oto. Sa dami ng nakapila pa rin hanggang ngayon (yung iba di pa nahuhugasan 'til now, as in puro putik pa rin loob at labas, yung iba nag-crack na yung putik sa tigas) eh baka lalong abuting ng isang taon yung oto ko sa kapapagawa hehe.
*battaglin - Saan yung Love electronics sir? May kontak number ka nila?
Tumatakbo na pero mataas ang idling, nasa 1800rpm. dinala ko na lang sa suki mech, binuksan throttle servo, di naman daw damaged so kabit uli. voila ganda na uli takbo, back to normal na menor.
- Nov 2007
- 246
January 21st, 2010 12:59 AM #5sori wala ako number love electronics. sa antipolo city ko pinagawa ECU. may branch sila marikina tuason ave. try mo mga nagrerepair tv o appliances. yung lang kasing Love electronics nakita ko may sign na nagre-restore sila car compu.
yep, nakabit na new TCM nung mapansin ko ung high idling. di ko kasi magamit nung luma TCM, kumakalabog pag shift e.
Speedlab sa Qave I heard tumatanngap ECU repair, 1500 ata initial charge.
- Nov 2009
- 21
January 21st, 2010 08:39 AM #6I see, yung akin kasi di naman sira yung ECU. Yung TCM at Throttle lang ang pinapapalitan. Yun lang sana gusto ko mapatignan muna kung kaya pa ayosin bago bumili ng bago.
high idle RPM at engine start
