Results 1 to 7 of 7
    Oct 2009
    my transmission on reverse wont work pag hindi maiinit temp ko.
    What could be the prob? i tried changing atf oil pero ganun pa din.
    pero once na maiinit na makina ko. smooth na yung transmission. problem lang kasi hassle ko need pa painitin para lang gumana reverse.
    honda esi
    May problem na linear solenoid mo, susunod jan di ka na makakapag shift.
    Oct 2009
    Quote Originally Posted by reym View Post
    napapagawa pa ba yan? or need ng mag palit ng transmission?
    Napapalitan yan. mas mahal ang AT transmission. Un sa Brother ko crv 2000 40k ang bili nya surplus. Pero kung ako sayo benta mo na car pag ka gawa bili ka na lang ng manual mas mura maintenance.
    Quote Originally Posted by tonzi View Post
    honda esi
    You can have your A/T tranny replaced with a surplus unit. It should cost you less than P20K including labor. The surplus tranny itself would be around P12K.
    The remaining balance would be for labor, ATF, and other minor stuff.
    But if the problem is just the solenoid, as "reym" suggested, just have that part replaced so you can save money since the rest of the A/T tranny seems to be working fine.
    Oct 2009
    guys does changing solenoid means overhaul of tranny?
    No. It just means they are replacing the electric linear motor that helps you shift into reverse. As for removing it, it depends on the tranny/engine design if they need or don't need to remove your tranny from your car.
a/t reverse need painitin before gumana.
